Question about Refrigerators
Zfsb26dnass ge monogram
Back of fridge jas frost on external parts
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
peyton32034
  • 410 Answers
SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
Posted on Jan 21, 2009
rockitman187
  • 2559 Answers
SOURCE: How often are you supposed to change the filter? (GE Monogram)
GE recommends once a year for the water filter for light use and twice a year if used heavily.
Please take time to rate this fixya.
Posted on May 11, 2009
SOURCE: GE Monogram will not accept freezer/fridge
My ge monogram gets warm every year this time of year. All of a sudden no ice and everything defrosts. We vacuumed vents up top last yr and it got cold again. What the heck???
Posted on Aug 01, 2009
SOURCE: red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Posted on Aug 19, 2009
There is a control panel reset for my GE Monogram side by side, Model # zfsb23dnss, It was "repaired" with a new board and now will not cool or freeze, HELP
There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
Jul 01, 2016 | GE Monogram Side by Side Refrigerator
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
Hi My GE Monogram Fridge isn't cooling very fast. It takes forever for it to get to 37 F. The freezer works fine. I have noticed frost build up in the fridge (not freezer) near the back (there is a vent...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 01, 2011 | GE Monogram ZFSB26DRSS Stainless...
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Red door spring GE monogram fridge side door
Jun 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Jun 06, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Fridge and Freezer are Warm Ice is still being made
Hi - I just had the same problem on a 48 Monogram 1996 model.
The guys at the factory told my local service center that it was the main logic board ($200 for parts) and they replaced it, but that wasn't it.
It was the evaporator sensor. i don't claim to understand it all, but I think that the sensor is responsible for telling a heating element to turn on and defrost. If it does not do it's job, then frost builds up (You can feel the frost if you feel up in the freezer, up hight and in the front)) The frost keeps the cold air from getting to the fridge. Eventually the logic unit will freak out because ti is trying to keep the fridge cold, but the fridge send back that it is hot.
The repair guy may not want to replace the sensor because it is like an hour and half to get back in there. And it is a tight fit.
Apr 17, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ge monogram sidebyside refrigerator
check the flap thats lets the ice come out,i don't think its closing all the way,thats why your getting frost,the water dispenser problem is the water inlet valve on the lower back of frig. and should be replaced,let me know more-mike
Oct 21, 2008 | GE Monogram ZIR36NMRH Refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
