Question about Dishwashers
Colged dishwashers MODEL TT820 DISPLY SHOWING SAFETY LEVEL HOW TO RUN THE MACHINE
  • Coss May 17, 2014
    Hi MUGUNDHAN , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? More information on the make and model first, and is it actually showing "safety level" or is it showing some kind of code number?
2 Suggested Answers
emissionwiz
  • 79186 Answers
SOURCE: Hobart dishwashing machine MODE- CLP66E disply show check water level & temperature low
Did you check the water level and the temperature as it sees a problem.
Posted on Jan 24, 2017
Jan 23, 2017 | Hobart Dishwashers
Fagor dishwasher is showing F2 please help.
Not drained in time allowed (6 minutes) - washing machine fails to drain water
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Aug 12, 2016 | Fagor Dishwashers
Colged dishwashers 820 schematic diagram
Try white goods (washing machines, tumble dryers, dishwashers) category, you may get the answers you need, this is PC laptops.
Jan 09, 2014 | Computers & Internet
Toshiba E-Studio 182 Digital Copier disply not getting
toshiba e- studio 182 photocopy machin screen was blank showing
Sep 14, 2012 | Toshiba E-Studio 182 Copy Machine
My dishwasher is showing error code a10 model ide 1005
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Dishwashers
Hi I have a Bosch dishwasher . The red tap symbol is showing . The little filter pump is spinning but not pumping . It continues to run when door is opened . Can you help please
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. If it doesn't come off then you will need to remove either 1 or both of the side panel, its just a number of screws holding them. Then see if you can see where the leak is coming from, you may need to order a new part. Hope this helps.
Mar 07, 2011 | Bosch 24 in. SHV55M03GB Built-In...
My 13 year old Maytag washing machine has been running fine. Tonight, I loaded the machine, it filled with water, but now will not run.
The most common problem to check is the lid switch. Depending on the model you may have a safety switch also and a fuse. If the fuse is bad the safety is prob. bad. Please rate my response. If you have more questions please include model #.
Dec 14, 2009 | Dishwashers
My kenmore dishwasher model66516034401 does not
do you have a sprayer on top portion of dishwasher? if you do make sure it turns when dishwasher is running. check to see if holes in sprayer are open and not colgged up. you can clen it by pacing it in vinegar.
Aug 20, 2009 | Kenmore Dishwashers
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Dishwasher wont fill after repair
first check to make sure the water is on then take the kick panel off and make sure the float is engaging the safety switch and the valve is plugged up if all that's ok check to si if the mirco safety switch is good
Feb 11, 2008 | Dishwashers
Dishwashers Logo
114 people viewed this question
Top Dishwashers Experts
