Question about Honda Garden
Mower won't start - Honda Garden
    Master:
  • 969 Answers
Remove old gas. Remove carb bowl and clean. Ensure float is working, float down gas flow. Float up no gas flow. Use a bread wrap, clean off 1 1/2 in to expose wire. Insert wire in tube from bottom of carb up to behind choke flap. Ensure needle valve moves smoothly when float is moved up & down. Remove plug, should be wet if gas is getting to cylinder. Ensure air filter is clean. Ensure oil has been changed and filled properly. Ensure primer bulb isn't cracked. Pull recoil rope twice half way to prime carb then pull all the way.
Posted on Jun 20, 2016
Mower won't start
Glenn, check the lawn mower engine trouble shooting links below for engines that do not start.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Top 5 Mower Troubleshooting Tips Briggs Stratton
Lawn Mower Won Start Here The FIX
May 07, 2016 | Garden
The mower won't start
Rocky , start by replacing spark plug and remove old gas for new.
check links below for why mowers do not start.
When Lawn Mowers Won Start
Mar 21, 2016 | Garden
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Won;t restart..
Check battery,if it's good, check charging system.
May 08, 2009 | Garden
My lawn mower doesn't start and when it does, smoke comes out of exhaust
you may need to change the oil and/or empty the old gas and replace it with new.
This thing happens when you don't take care of your lawn mower for too long.
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
65 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
