SOURCE: Hi,this car is actually a Vauxhall Meriva, but
should be behind the plastic cover below the wipers on passanger side i think but be carefull when you remove the top of the box cause it will set the alarm off DONT LEAVE THE KEYS INN THE CAR it might lock depending on the system
SOURCE: my vauxhall meriva radio shows
Leave it SWITCHED ON....UNDISTURBED for as long as it takes to automatically reset itself
This may take an hour or more
SOURCE: where is the fuel pump relay on a 2004 vauxhall meriva
It is on the passenger side of the engine compartment under the wiper panel. its deep in because of the body design. you'll see a relay box. It should click on and then quickly off when the key is turned to run without starting the engine
SOURCE: i have a warning light on my vauxhall
Emisions related can be a lot of things. It would have logged a fault code to the computer. You need the vehiclescomputer scaned to reveal the fault. Could be lots of things (O2 sensor in the exhaust, airflow sensor, vacume leak, misfire, etc...) the only way to know will be to have the code extracted.
SOURCE: allumination light on meriva dash has gone out
you dont you remove the whole panel and as they are LEDs then its a new complete panel i would imagine
