Question about Kenmore Dryers
Blowing cold air - Kenmore Dryers
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You either need a thermal fuse and or gas valve coils, both are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these two wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
My air conditioner is blowing cold then hot air.
Check your thermostat or battery backup or both..change or replace if necessary..
Dec 02, 2017 | Heating & Cooling
2000 satin sl1 heater blows cold air, had the
my 2000 saturn sl blows cold air with the heater on. I changed the thermostat,and checked out my heater core.Still blows cold air.
Jan 17, 2010 | 2000 Saturn SL
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Nissan xterra..2000
your air con needs re gasing
Jul 07, 2009 | 2000 Nissan Xterra
Dryers Logo
52 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
