Question about Garden
What ratio mythlated sprit to fuel to remove water
Water in motor need to clean out system without pulling apart
5 Suggested Answers
  • 154 Answers
SOURCE: removing rear wiper arm 1992 grand caravan
If this is a factory wiper arm look at the area where it hinges. There should be a small hole in the metal. Find a drill bit or shaft that fits the hole. Lift up on the arm, insert the drill bit. When you release the arm it should be raised of the glass supported by the drill bit. Now without pressure applied to the glass you should be able to wiggle it off the shaft of the motor. Hope that helps.
Posted on Apr 01, 2009
MNTECH
  • 1543 Answers
SOURCE: We have hard water deposits on the pump and motor not cleaning
Without a model number, or even a brand / manufacturer, it is nearly impossible to tell you how your product comes apart. Many brands have a screw (often times with left hand threads) holding the spray arm on, while others may come off by just lifting on the spray arm while turning it CCW, or might have locking clips which need to be released.
In any case, before going that far, go to a hardware, appliance parts, or possibly grocery store to find a product called Dishwasher Magic. It is in a small rectangular bottle. Use that as directed in a cycle to clean out your dishwasher. The spray arms may need to be cleaned out of blockage from candy wrapers, toothpicks, seeds, etc., or possibly even replaced if unable to fully clean out. Also, dishwashers will not clean very well if you are using hard water. I'd suggest looking into installing a water softener.
Posted on Jul 26, 2009
  • 223 Answers
SOURCE: 87 sable will not start
Alcohol can do it, if you have time to wait. If you don't want to wait, put about a tablespoon of Dawn dish soap in a small amount of gasoline, about a quart, and mix well. Pour in tank. If you have ice in the fuel system you'll have to thaw it, but the dish soap will pick it up once it thaws and the motor is running. You may have trouble with a plugged fuel filter or two and you may not, depends on how much dirt the dish soap picks up.
It's all about making oil and water mix, like when you're washing dishes.
lp
Posted on Jan 16, 2011
  • 7353 Answers
SOURCE: i have a honda 2002
in the fuse box, it may be marked, or in your owners manual. Chefk them all, then you will know if any fuses are bad. Usually its the sensor if the fuses are good.
Posted on Aug 26, 2011
Fuel injection pump problem
the only way for water to get into the pump is from water in the diesel
clean/drain the water separator( if it doesn't have one then fit one in the supply line)
drain /clean out the fuel tank
use a diesel fuel conditioner
always fill the tank to reduce condensation when not in use for periods of time
you cannot pull the pump apart as it has to be reassembled and calibrated on a special test bench by an accredited diesel specialist
best if you discuss the reconditioning or service exchange of the pump after removing all of the water from the system with a specialist diesel shop
Jun 21, 2017 | Heating & Cooling
How do you check the valve clearance on the dirt bike. I am trying to figure out why my motor seized up without taking apart the top end.
motors seize up from over heat or lack of lubrication
check sump oil level and coolant level in the radiator
Possible hole or bad hose
Nov 21, 2015 | Motorcycles
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
97 ford 4.0 sohc runs rough has power changed plugs wires thinking maybe egr vavle
timing or bad fuel or head gasket will cause this .
take off radiator cap & run the motor if it blows out coolant when you pump the fuel pedal in the car its head gasket you may need two people if you don't have a rubber neck to look out the window if that's ok try the fuel water in fuel will do this to mix in some mentholated sprits (metho) to the fuel tank 1 litter to a full tank of fuel the metho will mix with the water and burn off when it enters the piston chamber ( try this in a glass of water 1st if your sceptical ) .
or use a fuel cleaner from your local auto shop
good luck
Apr 05, 2014 | 1997 Ford Explorer AWD
My 1998 GMC jimmy won't start without starter fluid sprayed in the air intake on top of the motor.a small sprits and she starts right up.what do i need to prevent that everytime startup issue.
Your fuel pump isn't putting out enough gas to turn over motor it needs over 14lbs per square inch of pressure to start even though it only needs 12 to keep running. you will have to replace fuel pump.get acdelco and you ill never have to replace again.
Mar 21, 2011 | 1998 GMC Jimmy
New plug, fresh fuel and new oil, statrts but when auger engages snow it stalls?
I would suggest you pull the carb off and clean it with mineral sprits or some other cleaning solution and blow it out with air and try it.if that don,t work you should replace it with a new one.
Dec 28, 2010 | Garden
I have a Yamaha TTR 225 four stroke that is having engine problems. When trying to start the dirt bike a fine mist of starting fluid must be administered to the carburator or else it will shut off within...
If it is a fuel delivery problem, I would start by pulling the gas tank, dumping it out then pulling the petcock on the bottom of the tank and clean the pre-filter with compressed air. Next, pull the carb and take it apart - they are fairly simple and you can get into it without needing to buy any parts. It's possible there is just water or other junk in there that needs to be removed. Clean it really well and put it all back together with fresh fuel and a clean air filter and try it again.
It's also a possibility that your engine compression is low. These things need new rings every once in a while. Keep in mind I know nothing about the age or condition of this bike.
Nov 12, 2009 | 2004 Yamaha TT-R 225
How do I clean the carb on my Lawn Mower
Without completely removing the carb you can just start the engine and squirt carb cleaner in it after removing the air filter. If it needs additional cleaning(float sticking,dirt in the bowl, gas overflow etc.) you'll have to pull it from the motor and take it apart.
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Put atv in water
If it is what I think it is, drain the whole motor. Oil, coolant, fuel, all of it take the plugs out and once the motor is clean, dry fire the motor (turn the key or use the pull cord) without the plugs in and that should get most of the water out of the cylinders.
Go through the electrical system and check for shorts, bad fuses and your battery, if there is one, should be changed
Apr 13, 2009 | Sport & Outdoor - Others
Maytag, Quiet Partner II. Top water wheel is not getting does not get sufficient water pressure. Without sufficiant water proessure the water wheel won't spin, without the spinning effect dishes on top...
Motor-Pump Drive assembly is defective.Hey while you have this machine apart pull the drain pump off and look for a jammed flap,it's rare but check it anyway.(to remove the drain pump just twist it and pull it off).For the non believer's out there ,this will be a learning experience.You will NOT resolve this "not clean dish" problem unless the Motor -Pump assembly is replaced with the one they now make that works. THIS to some repairman was called POWER DRIVE ASSEMBLY. Quick note: motor - pump does NOT include the drain pump.Think about that for awhile.Any way the drain pump will not be the problem,the Motor-Pump is!
Jun 11, 2008 | Dishwashers
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
