Question about Konica Minolta magicolor 2430 DL Laser Printer
Can you explain how to remove the fuser on my KM 2430dl printer? I have fragments of paper that are jammed in it and I'm told if I can remove the fuser and rotate the rollers manually it may help. The manual does not say how to do this. Thanks
    Sergeant:
    Champion:
  • 253 Answers
Hi open the door at the back side of the printer and then turn the roller
u can also call us at our tollfree no 18884276640
Posted on Jun 23, 2009
I have recently had a paper jam in my HP Laserjet 100 color MFP M175a printer.getting the error message "jam in output bin. Open rear door and clear jam"
You should check inside the fuser at the back of the printer. Probability is that there is a folded sheet or fragment of paper still in the fuser. It may be readily accessible in which case open the tensioning clips either side and carefully pull the offending item free. If you can't get at it, the fuser may need to be removed and dis-assembled.
Oct 25, 2017 | HP Office Equipment & Supplies
How to repair j40 problem in km-1500
J40 means that you have a paper jam located in the fuser unit of the machine (the hot part)
You will need to locate and remove the jammed paper.
Faulty fuser sensor.This may need to be looked at by a technician.
Aug 07, 2013 | Kyocera Mita Office Equipment & Supplies
I HAVE A MEDIA JAM FUSER PROBLEM, WAHT CAN I DO TO FIX IT?
Well a media jam is a paper jam remove the paper. Remove the transfer belt or the fuser what ever is required. chk web site for owners manual. Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 25, 2011 | Minolta 2430DL Color Laser Printer
Paper jam in fuser unit after heating in canon i 3035
To remove the paper jam you will have to open the fuser unit to take out the paper fragments inside.
sonsunny
Jul 05, 2011 | Computers & Internet
The paper stuck in the printer. What should I do? How can I get it from printer?
stuck where one is left to wonder...., one removes jams by open rear door or front and removing toner, or cassette, if it is crumpled in fuser, then it aint easy without pulling it apart, sometimes a manual feed via hand of a pice of stiff card or laminate in direction of paper path (dont pull it against direction nor should jams be pulled backwards), cut a point in lamiante to allow you to poke then pull threw removing paper fragments
Nov 07, 2009 | Brother HL-2040 Laser Printer
Fragments of paper inthe fuser
The only way I was able to clear fragments of paper from the fuser was to remove the fuser it was then easy to remove the paper fragments. Before you do that you could try manually pushing a 5 inch strip of a manila folder up through the rollersl although that did not work for me.
Aug 02, 2009 | Konica Minolta magicolor 2430 DL Laser...
Canon ImageRunner 2800 toner buildup
YES this parts is for cleaning purposes to collect toner that was building on the pressure roller .replacement of this assembly is needed if thick toner waste accumulates on the roller
Jul 16, 2009 | Canon Office Equipment & Supplies
Vertical lines appearing on my 2430DL Konica magicolour Printer.
laser scanner assy is what puts image on on to drum,which prints out on paper.ther fuser is where toner fuses to paper.
Jun 30, 2009 | Office Equipment & Supplies
Media Jam - Fuser Error
if the paper comes out and you get still this message, then probably you have a wrong paper format or fusing unit solenoid is stuck.
Aug 09, 2008 | Minolta 2430DL Color Laser Printer
Xante cl30 color laser printer paper jam
Remove the fuser and examine it closely (Note: the fuser gets extremely hot. Wait until it has cooled completely before touching it!) Paper or a paper fragment might be balled up inside it.
Even just re-seating the fuser might clear the sensor that is reporting this jam.
If the printer continues to stall with this error code, even though there is no jam, it could have a faulty sensor. This would have to be repaired with a service call...
Mar 06, 2008 | Xante CL30 HSE Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
570 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
