Question about Toshiba Office Equipment & Supplies
IN TOSHIBA PHOTO COPIER 212 NO TONER RECOGNIZED ERROR SHOWING
  • 208 Answers
SOURCE: xerox 212 copier
Most likely replace the fuser.
And be sure you use transparencies marked for copiers only.
The U4 is an over heat because the tranaparency stuck between the heat roll and the thermistor. Causing the fuser to stay on and blow the overheat.
Posted on Dec 04, 2007
SOURCE: Toshiba E-Studio 45
I HAVE TOSHIBA E-STUDIO 45, AFTER WARMING THE THE #66100 CAME UP. I DON'T KNOW WHAT IT MEANS. PLEASE HELP.
THANKS
Posted on Dec 07, 2008
  • 2072 Answers
SOURCE: copier 212 error code U4
That is a fuser code. May be a bad heat rod or just need reset.
Here is how to reset it.
Enter diagnostics, Here is the procedure.
To enter diagnostics:
Hold down ‘0’ while turning on the Power the console will light up. Press ‘Stop/Clear’, the lights will shut off & --- will appear in the display Wait 30 seconds for the optics to complete a self-test before you enter any diagnostic test codes. Never turn off the power before the optics stop moving (or you’ll get a U2 code & possibly some unpleasant noises from the Scan Drive Motor).
Next setp is to use the code to clear the U$ code.
*To clear a fuser code:(401)
Enter diagnostics, wait 30 seconds for the optics to initialize, enter ‘401’ followed by ‘Print’, then shut down the power & wait 10 seconds before switching power back on.
That will normally clear that problem. Often times when a machine has set for a long time they wont warm up right and pop that code.
Another thing, if you can get the machine to warm up and come ot ready then it pops up a U4. Open that right side door. You will see this silver, looks like a small saw blade. It should be silver, but it will have a lot of ink built up on it, take a soft brush and clean it with that.
Let me know, if hte code 401 doesnt clear it, then the heat rod would have to be replaced. If that happens please let me know and we will procede from there.
Posted on Jan 30, 2009
frcs68
  • 1605 Answers
SOURCE: Copier makes faded copies, even though it has toner
the heater unit is the problem.
yo can get a repair kit by search on the Internet or go to Toshiba web site.
the repair kit come with instruction, if you can handle the mechanic part of things. then you are all set.
Posted on May 19, 2009
  • 5 Answers
SOURCE: Sir, My copier model RICOH MP
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Posted on Sep 06, 2010
Testimonial: "Sir, Thank you so much for your help, let me try in my copier and revert back once the problem is solved. Thanks Gopalkrishna T N"
What happened if toner not recognized in toshiba e studio 225
This model no code to bypass...Make sure you are using genuine toner with toner chip on it...Then, clean the toner chip(with 6 springs) and harness inside the machine...If still persist, u might need to change the toner chip on the machine...
Aug 11, 2015 | Toshiba E-Studio 225 Multifunction Copier
Black Toner Cartridge Not Recognized.?
Check the contacts on the toner cartridge and in the printer are clean and shiny. They also must have no dent.
We on Fixya only try to answer questions via this page. We don't send mail.
Mar 13, 2015 | Toshiba E-Studio 356 Multifunction Copier
TONER NOT RECOGNIZED
TOSHIBA 237 RECOGNIZED ERROR
Mar 08, 2014 | Toshiba E-Studio167 Copier
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
Sir i have toshiba e studio 212 machine when i on her empty toner replace toner appear the msg on screen what is the solution
Need to go to an office products company and purchase a toner cartridge. You might be able to have your toner cartridge refilled for half the cost of a new cartridge $80.
Aug 17, 2013 | Toshiba e-STUDIO207 Printer
Toshiba E-studio 212 How do diserbleToner recognition sensor
Oddly enough, I just had the same problem with "OEM" toner. The chip on the toner bottle was not working correctly. I installed another toner & the bottle was detected. The bottles that did not work I throw out. You may want to try to return the bottles that are not working correctly.... Good Luck
Apr 11, 2013 | Office Equipment & Supplies
Toshiba e studio 212 photocopier machine change the toner but massage low toner
The toshiba machine e studio 212 is zerox actual image on in side tray but we are select out side try the image is shifted on output paper.
Aug 16, 2012 | Compatible Toshiba T1810 For E Studio 181,...
Dear sir, i have toshiba e studio 212 photocopier machine I change new toner but give the massage toner low
on out side tray the actual image is garbage left side 1 inch but in side tray select the image is actual printout
Toshiba e-studio 211 copier .Toner sign not remove please halp me anwerali78@yahoo.com
Machine shows "Toner not Recognized" when correct toner is inserted into MFP.
It can be due to main PCB faulty.
May 28, 2011 | Toshiba Office Equipment & Supplies
18 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
