Question about Panasonic Hdc-mdh1 Hd Camcorder pal Mdh-11 Year Warranty
Why Panasonic HDMDH1 Focus error - Panasonic Hdc-mdh1 Hd Camcorder pal Mdh-11 Year Warranty
What do I do about my Panasonic Blue ray player BD 871 not playing Blue Ray Discs?
The laser mechanism has lost its ability to focus properly. Not cost effective to repair. Get a new one.
Sep 29, 2016 | Panasonic Televison & Video
What does FO2 MEAN ON PANASONIC MOVIE CAMERA
. Error Codes Panasonic JVC Description F01 . No Take-Up reel rotation F02 E03 No Supply Reel rotation F03 E02 Mechanism has not unloaded to the Eject position F04 E01 Mechanism has not fully loaded up to the stop position F05 E04 Rotation of the video head has stalled or too fast . E06 Tape drive motor is not rotating or stalled F31 . Data Transmission error F51 . Focus drive motor is not functioning, no focus. Color F52 . Zoom drive motor is not functioning, no zoom U10 . Dew Sensor has detected condensation or failed U11 . Video Heads have been detected as clogged failed
Nov 14, 2014 | Cameras
Panasonic LUMIX DMC-FH4 is showing system eror focus. How solve it ?
Can you tell exactly what is on the screen please. The system error focus is not supposed to be an real error that is displayed on your camera.
"System error" is possible. But if switching of and a few moments later switching on does not change the error on the dis[lay, you should contact a Panasonic certified repair centre.
May 24, 2014 | Panasonic Lumix DMC-FH4 Digital Camera -...
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
Panasonic lumix dmc-fx37. Two error messages are now appearing. System error zoom system error o.i.s.
sounds like the focus and (Optical Image Stabilization)drive motors are bound or broken, sadly this normaly means new camera, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well ya know, they will normaly repair or replace it as long as it is due to manufacture defect.
Mar 16, 2010 | Panasonic Cameras
Panasonic SDR-H40P Hard Disk Video Camera loses focus
Keep it still roughly 5-6 seconds in the same spot and it will re-focus
i had that once
Sep 06, 2009 | Panasonic SDR-H40 HDD Camcorder
Camera having error WARNING FOCUS LOCK
Hello there! Focus ring lock means that some how the focus ring is not turning freely. If it turns easilly then inside the optocoupler unit which reads out the movement of ring must be dust or damage.in the flexicable. Therefore somehow the camera should be disassembled got cleaned by pressurized air in case of dust and reassembled and hopefully it should work without problem.
Aug 12, 2009 | Panasonic AG-DVX100 Mini DV Digital...
Camera focus error
there is a small logic circuit that controls the motor that retracts the lens and a sensor that tells it the lens is retracted, it is a lens position sensor, one of these two components is most likely defective, the thing is there are no consumer service info provided by panasonic, they will not sell you parts either, the camera is a mystery to take apart and repair without the tech manual which u can't get, so u see the delima here, u must either have this camera fixed by a panasonic repair station or see if it qualifies for a upgrade exchange program for a newer model.
Aug 07, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
F01 error on playback or recording - Panasonic NV-DX100
F01 No Take-up reel rotation
F02 E03 No Supply reel rotation
F03 E02 Mechanism has not unloaded to the eject position
F04 E01 Mechanism has not fully loaded to the stop position
F05 E04 Rotation of video head has stalled or to fast
F31 Data transmission error
F51 Focus motor is not functioning, No focus
F52 Zoom motor is not functioning, No Zoom
U10 Dew sensor has detected condensation or failed
U11 Video heads have been detected as dirty or failed
Matti Knuutila mattik1999@yahoo.com
Jul 11, 2009 | Panasonic Video Cameras
Panasonic Hdc-mdh1 Hd Camcorder pal Mdh-11 Year Warranty Logo
49 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
