How do I fix this problem: When TV is turned on.. screen shakes and is blurry.. there is a white line that flickers on the right of the screen. When I tried Touch Focus.. the Green, Red and Blue 'Vertical' lines are squigley or shakey.. However.. the Green Red and Blue Horizontal Lines are Sharp and not shakey or Squigley at all. The longer the TV is on.. it gets a little better.. but as soon as I turn the TV off.. and turn it on a little later it does that same thing all over again. Problem is getting worse and worse.. Can Anyone help me solve this problem? I have technical skills I can solder.. etc.. just need pointed to the right direction!
  • 69 Answers
There are two big chips,called convergance chips one of them is failing ,they cost about
10.00 -30.00 etch never more than that.
Posted on Jun 24, 2009
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Lines and blurry screen
hi, sounds like u need some solder joints re-worked (probably quite a few for a set that old, but your right it`s a great set), price varies by region greatly, I`m in central florida we would charge 75 for service call & 95-125.00 for labor depending on how long it takes to do the solder rework, hope this answers your question, get it fixed it`s waaay better than the new hd (ha ha ha) sets, video-tek
Jun 02, 2009 | Hitachi Televison & Video
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Monitor blurry or black
The problem could be with the LCD or the Video chipset. Either repair is expensive. I would figure about $150 in labor plus part cost. You can try ebay to get an idea of the part cost.
At 4 years I would be leaning towards purchasing a new laptop.
Dec 30, 2007 | IBM ThinkPad R40 2897 Notebook
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
