Question about Brother MFC 9180 All-In-One Laser Printer
Printer mfc 9180 suddenly prints dark and dirty
I installed a new drum recently. It printed satisfactorily for a few week, but is now printing dark and dirty. How can I fix this problem?
SOURCE: brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Posted on Nov 25, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Posted on Jan 25, 2008
Adi_Taticu
  • 71 Answers
SOURCE: I've recently installed a new Brother toner, but
DRUM UNIT "spent"
It can be reset if the printing quality is good
To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Oct 09, 2009
Testimonial: "A first rate resolving of the drum problem on my Brother HL 5140. Thanks very much, Fixya."
Semi-Driver
  • 434 Answers
SOURCE: Brother MFC-5890CN Printer
It sounds like your print heads may need cleaning. However, here is the link from Brother support for your MFC-5890CN on how to improve print quality:
Brother MFC 5890 Print Quality
Posted on Jan 15, 2010
  • 59 Answers
SOURCE: yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Posted on Apr 24, 2010
Testimonial: "thanks, very helpful. I will try the suggestions here"
Brother MFC-440CN - print quality terrible, almost non-existent in spite of many cleaning operations.
It sounds like the printhead needs to be replaced. Brother may cover the cost of repair if you call them at 877-276-8437 and tell them the prints are "missing black ink". Very common problem that a new printhead should fix.
Oct 08, 2012 | Brother MFC-440CN InkJet Printer
I have a mfc-8440, 5 years old, low usage, 50% drum life, new toner cartridge. The problem is that the contrast of the printed copy does not change regardless of the setting using the path...
This is very easy to solve. Remove the drum and toner cartridge. Look into the machine where they sat. Now look up and you will see (a little aukward but its there) a glass plate the width of an A4 sheet of paper. Run your finger accross it. Look at your finger and will probably be dirty. This is the window the laser beam passes thru to hit the drum. When its dirty it does not allow enough ;light to the drum hence a weak beam and light printing.
simples?
May 18, 2011 | Brother MFC-8440 All-In-One Laser Printer
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
The Print has white stripes
White stripes are caused by dust and toner powder on the scanner window, which is situated in the bottom of the printer, under the drum unit. Open the printer, remove the drum unit and using a soft cloth with a little meths wipe the window clean of toner and dust. It's quite dark inside the printer, so use a torch to find the glass panel (only about 10mm deep x the width of the drum).
Jun 24, 2009 | Brother MFC 9180 All-In-One Laser Printer
I have a brother mfc 9180 and the error message keeps coming up replace the drum. I have done this How do I reset it
your new drum should have had a plastic "starter sheet" installed just level with the exit hole. this sheet resets the counter, and should not be removed before fitting the new drum. The sheet will be automatically ejected when you have fitted new drum. If you still have this sheet it can be refitted to the drum, then reinstall the drum. Works for me ! MFC 9180
Jun 05, 2009 | Brother MFC 9180 All-In-One Laser Printer
Bold black lines across the paper when printing,scan or copy not on faxing
I realise this is probably too late for you Janet and you will have bought a new drum unit by now or replaced the printer! The three lines appeared on my print-out from a new drum I installed and after investigation it transpired that there was some toner residue that had dried on the drum (from testing at manufacture stage probably) and reprinted three bold lines on a sheet of A4. The solution is to use a soft piece of cloth and rub the lines off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the reside has been removed from the drum and it is clean, the lines will have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Apr 13, 2009 | Brother MFC 9180 All-In-One Laser Printer
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Dark mark at the edge of the page from top to bottom when printing
sometimes dirty carona, clean with blue tab on drum, if not then usally it is the drum worn out(expected life 20 000 prints) or less often it is the fuser roller stuffed
Jan 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 9180 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
