I have a kenmore HE2 electric dryer. the power comes on (panel lights up) but when i push the start button it clicks like it normally does but the dryer cycle does not begin. i waited through the cycle and the alarm came on at the end of the cycle as though it was in normal cycle. it seems that the only failure is for the heat and drum cycle to operate.
  • 2 more comments
  • rricejr673 Jun 23, 2009
    please reread my question the problem is with my HE2 Electric Dryer not the washing machine. Thanks.
    nope, the belt is fine and spins with the drum (there is resistance). i'm wondering about if it may be in a switch. i hear the electrical click that i normally hear just before the drum begins to turn and the heat would come on. the dryer goes through the whole cycle and beeps as though it has gone through the cycle. what is it that tells the drum to turn and the heater to come on?
  • rricejr673 Jun 24, 2009
    it seems to be the 1.5 inch switch/fuse but i'll have to take it in tomorrow to have it checked/replaced. thanks for the help.
    thank you for the help
  • 10,515 Answers
The problem sounds like the motor to transmission coupler. If it is not draining or spinning you may find that the lid switch is inop.
A complete troubleshoot guide would be :-
There are many parts that have to do with the Whirlpool washer not spinning.
The first thing you need to check is the wall outlet to make sure that there are about 120 volts present at the outlet.
The lid switch also know as the door switch, has to be working in order for the washer to be able to drain or spin.
The motor coupler is the part that transfers the rotation of the motor, to the transmission.
When the motor run in a counterclockwise direction the washer will agitate and when it runs clockwise the washer will spin. A broken motor coupler could be the reason when the Whirlpool washer is not spinning or agitating.
The basket drive block is the part use to couple the spin drum to the brake & drive tube. A broken basket block will stop the washer from spinning.
The clutch is the part use to make the washer spin. A broken clutch cam driver could be the reason why your washer is not spinning The brake and drive tube is the part responsible for stopping the spin drum when the washer is agitating and for spinning the spin drum when the timer calls for spin.
The transmission is the part in charge of making the washer agitate or spin according to the rotation of the motor.
The motor is what makes the washer work. A motor that overheats could be the reason why your Whirlpool washer is not spinning.
The timer is the brain of the washer, it is a distribution center that distributes the electricity to the different parts in the washer.
As you could see there are many parts that could be the reason why your Whirlpool washer is not spinning. You will have to check each one of the parts mention until you find out which one the causing the washer not to spin.
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
  • 1 more comment
  • taran_2005
    taran_2005 Jun 23, 2009
    Oops, Bingo!!!!!!
    If drum spins very easy. Belt will have resistance. If dryer has bottom
    access panel, pop it off and you'll see belt laying on bottom - Belt is BROKEN.
    Unless, My suspect would be "MOTOR".
    Check and let me know.
    Hope i helped you.
  • taran_2005
    In this case, i bet you have Faulty Motor that cannot sustain load. Still, regarding the switch, yes in few models of Kenmore, there are 2 fuses.
    Remove the rear cover and there are two fuses. One is a little white
    fuse about 1.5 inches long, located near the middle toward the bottom
    on the blower housing. The other one is on the left side of the
    heating element canister toward the top. Check both of these for
    continuity and let me know what you find.
    Hope i helped you.
  • taran_2005
    taran_2005 Jun 24, 2009
    Thanks for you response.
    Do let me know and Do rate the solution.
Start button broken
The start button is a removable and replaceable part. Order it on line to save money.
May 19, 2014 | Kenmore HE2 Plus 3.6 cu. ft. Front-Load...
HE2 Plus Washer starts then shuts off immediately.
Aren't microprocessor controlled appliances wonderful? Especially when the code is flawed! No wonder the space program bit the dust!
May 12, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 dryer will not start
the relay for the motor is probable stuck recommend service
Jun 03, 2010 | Kenmore 82822 Electric Dryer
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
My electricity went out now my kenmor dryer will not come on
Check the breaker in the main electrical panel and re-set it (re-set even if it appears to be on). Also check your owner's manual and see if you have a re-set button on the dryer itself.
Sep 01, 2009 | Kenmore HE2 Plus Front Load Washer
Our Kenmore Elite electric dryer does not start. Start button is pushed but only clicks. Thanks in advance.
MY KENMORE DRYER WOULD NOT START IT JUST CLICKED WHEN I PUSHED START. GOT ONLINE & SOMEONE WITH THE NAME JAKE SAID TO CHECK THE THERMAL FUSE. I DID WHAT HE SAID & IT WORKED SO MY HAND GOES OUT TO HIM THANK YOU VERY MUCH JAKE.
SINCERELLY. DANIEL STEED
Jul 12, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
Kemore he2 won't start
check the door switch make sure that it clicks when you push it. if not its probably not working
Jan 06, 2009 | Kenmore 82822 Electric Dryer
Start button pressed in and now won't start
you should have a tec come by and take a look thats a five min. job the sping insinde probly broke. hope this can help you.
Jan 02, 2009 | Kenmore 82822 Electric Dryer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
