Question about Multitech Systems OTC Genisys MultiTech 56K Pc. MCIA Modem Kit (WEOTC342107)
Need repair for scan tool determinator - Multitech Systems OTC Genisys MultiTech 56K Pc. MCIA Modem Kit (WEOTC342107)
Where is 2007 gmc acadia rear liftgate module located and how do I determine if it is the liftgate module control module or hands-free closing motor that needs replaced?
It's located inside the lift gate ,would need to take trim panel off to get to it . Determining if the module is bad would be done by hooking up a professional type scan tool to see if the module communicates with the tool , Checking for DTC'S - diagnostic trouble codes. Your best bet , take it to a qualified repair shop. Changing some of these modules would need to be programmed , dealer .
Oct 05, 2017 | GMC Cars & Trucks
ABS activates when coming to a stop,monitor says service ABS system and traction control system. 2005 Grand Prix
Use a OBD II scan tool to determine the possible components that are related to the problem. Many auto parts store provide a complementary scan. Not all scan tools will read the ABS module problems.
Wheel speed sensors are a common problem! The scan will ID what wheel is the problem if it is the sensor.
It may require for you to go to a dealer or service center that has the right scan tools.?
Hope this helps.
9692512-2dg00yxw3lqrbvftcilxz1ml-1-2.jpg Hope this helps?
Jun 05, 2017 | Cars & Trucks
What is a scan tool
A scan tool allows for the OBD II (On Board Diagnostics) codes to be read from the engine computer in a car. These are common electronic diagnostics tools used by automotive technicians. They are usually used when a check engine light comes on to determine the error codes associated with the check engine light.
They almost always connect via a standard plug on the divers side under the dash.
Most automotive parts supplier will check a car with complementary service to determine the codes stored in a customers automobile.
Nov 21, 2015 | Cars & Trucks
How do I fix the Auto LSDifferential light from flashing and CEL on on my 2012 RAV4 limited V-6 is on
You need to do a diagnostic scan test to determine the source of the problem and then reset the lights using a scan tool once repairs are made
Jul 01, 2015 | Cars & Trucks
How to reset the check engine light on a 2000 chevy cavalier
need a scan tool to plug into the ob2 port to clear unhooking the battery on the newer cars doesn't always work and may cause more issues such as computer will need to relearn the sensors again but using the scan tool you can read the code first determine if the issue is serious and use the scanner to clear it
Apr 14, 2015 | Cars & Trucks
98 lincoln navagtor
If the Security system light is on it indicates a fault has been detected in the system by the control module, you must have the system scanned with a special tool by the dealer or a well equipped shop to determine what is in need of repair to correct the problem. You may experience a no start if you don't get this looked at ASAP.
Apr 06, 2012 | Cars & Trucks
I have a 2003 VW Beetle TDI. I'm having some electrical issues with it and am looking for a shop to do the repairs. For some reason when you start it, the interior light stays on and there is a loud...
You need to find a repair shop that have a VagCom scan tool or similar. This will allow live data to be viewed to determine which switch is reporting a constantly open door and draining the bbattery. The wipersissue sounds like a worn switch.Phone around the local garages and find who has the necessary equipment first. Standard scan tool will NOT throw up a code for this.
May 30, 2011 | 2003 Volkswagen Beetle TDI
Code po420 on scan tool but o2 sensor was replace 2 months ago
Hello and welcome. the code P0420 is for a bad cat. converter. replacing 02 sensors wont repair this code. the code simply's means that thje cat. converter is not working as designed and will need to be replaced.
The PCM determines the oxygen storage capability of the catalytic converter has degraded below a calibrated threshold.
Jul 03, 2010 | 2004 Mazda RX-8
2007 aveo misfire faults
gm has a problem with this from way back. double check your spark plugs and if they are not ac delcos, change them. ive seen this time and time again swearing, myself, that there is no way that the plugs would cause this issue. it always comes up with random misfire and usually another 1 or 2 codes misfire codes. put in ac delco, no more codes. let me know
Feb 22, 2010 | 2007 Chevrolet Aveo 5 Hatchback
There is no power at the diagnostic connector of a 2003 Mitsubish Eclipse GS that I am working on. Any ideas?
Check the fuses, I'm not familiar w/ Mits., but I have run into 2 repairs where the diagnostic port would not provide engine codes to scan tool, both times it was a bad fuse, so no power at port (thought my scan tool was broken!) . One car (american manufacturer) had the fuse shared with the cig. lighter, check your fuse diagram to determine which one it is on your car. Hope this helps, good luck.
Nov 17, 2009 | 2003 Mitsubishi Eclipse Coupe
Multitech Systems OTC Genisys MultiTech 56K Pc. MCIA Modem Kit (WEOTC342107) Logo
52 people viewed this question
Top Multitech Systems Computers & Internet Experts
Vladimir Frolov
Larry Fostano
Larry Fostano
Karen Gibson
Level 1 Expert
Are you a Multitech Systems Computer and Internet Expert? Answer questions, earn points and help others
