Question about Sharper Image EV-HD10 Cool Mist Ultrasonic Humidifier-1 Gallon
My EVS1-HD30 Warm & Cool Ultrasonic Sharper Image Humidifier has no power supply
My Sharper Image cool mist humidifier is not putting out any mist. I am wondering if it needs something cleaned or replaced and, if so, what needs to be done.
If this unit is an ultrasonic mist device, the mist element could be defective. They should be quiet, but still purr along and provide ma mist. The best bet it to contact the manufacturer and if under warranty, replace the system.
Jan 12, 2018 | Sharper Image Humidifiers
I have the HD15 how do you clean it latly everything is covered in a chalky mist in the room?
Hello FREIDA GRAYDEN,
If you are not TOTALLY SATISFIED... and that has
the SHARPER IMAGE price tag...
(in y opinion... I would return it to SHARPER IMAGE
and us the REFUND to buy 3 to 5 equivalent units ...
(like HoMedics) for a whole lot LESS...!!
(in my opinion)).
More units... less WATER spritzing around =
HAPPY FREIDA (I think).
I sincerely believe... the "chalky" you speak of is
merely a product of the CALCIUM level in your
water... and a mist type of humidifier. Nothing
wrong with your humidifier (follow owner manual
cleaning instructions) BUT what you see is normal
Sharper Image EV HD15 Instruction Manual Page 3
THE VISIBLE "mist" Your humidifier puts out are
solid water drops... It WILL mark whatever it
lands on...
I think there ARE things you could try...
Obviously turning down the humidifier to
merely moist... rather than SPRITZING water
on everything (solid/visible).
Spread the load between multiple machines
(as described above)
Perhaps...filtered water might help
Dietary CALCIUM is a very good thing... and humidity
is much more warm and comfortable... but the combination
is going to give you those SAME results...
But at those SHARPER IMAGE prices I would
expect YOU to be TOTALLY SATISFIED.
Carnac the Magnificent
https://www.amazon.com/HoMedics-Cool-Mist-Ultrasonic-Humidifier/dp/B00EW1QJPS/ref=pd_sbs_201_2?_encoding=UTF8&pd_rd_i=B00EW1QJPS&pd_rd_r=S79PF7TS0FVV4D24Y2GP&pd_rd_w=jrPo2&pd_rd_wg=POkzf&psc=1&refRID=S79PF7TS0FVV4D24Y2GP
Jan 11, 2018 | Humidifiers
Sharper image ultrasonic humidifier #EV-HD10B leaking water
clean all the rubber washers. You may have crud preventing a good seal. Where is it leaking from specifically?
Jan 02, 2018 | Sharper Image Humidifiers
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
How do i turn it on
Copy the manual from here and follow the directions: https://www.sharperimage.com/pdf/EL100280%20userguide.pdf
Mar 03, 2015 | Sharper Image EV-HD10 Cool Mist Ultrasonic...
Motor runs but no mist comes out on EV-HD15
If there is water in it, it sounds like the ultrasonic unit failed.
Dec 05, 2014 | Sharper Image EV-HD15 Cool Mist Ultrasonic...
I need a tank cap for my EV-HD10 Sharper Image Ultrasounic Cool Mist Humidifier. I lost ours and don't want to buy a whole new humidifier. Can I find one anywhere?
Contact SI Products @ 888-856-6781.
After a long wait I spoke with a very professional guy who ordered it for me in just a couple minutes. Totally restored my faith in the retail Sharper Image Products.
Dec 26, 2011 | Humidifiers
Trane furnace humidifier not working
If there is water and power to humidifier you need a new solenoid valve or humidistat.
Jan 16, 2010 | Honeywell Power Humidifier: Furnace...
Sharper Image EV-HD10 Cool Mist Ultrasonic Humidifier-1 Gallon Logo
57 people viewed this question
Top Sharper Image Humidifiers Experts
rostit
Gil Shultz
Tom Chichester
Are you a Sharper Image Humidifier Expert? Answer questions, earn points and help others
