How can I fix my hp touchsmarth 300 screen, - Computers & Internet
How can I fix my hp touchsmarth 300 screen, doesn't load any website when I try to open.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Looks like the problem is with your wireless card/drivers. check in device manager to see which is the problem. also check there is not a switch on the front or side of the laptop.also look at your keyboard as you could have an f key and ctrl key function
Posted on May 17, 2014
Won't load windows
You may want to try pressing F11 before the Windows Logo screen and select the option to restore from a previous point.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01835735&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=4007372#c01835735_command
Using System Restore when Windows 7 cannot start normally Use the following steps when Windows does not open normally.
Show me how
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F11 key repeatedly as the computer starts.
  3. Under I need help immediately, click Microsoft System Restore.
  4. Use the steps in the Restoring Windows 7 to a previous point section to use System Restore.
Jan 05, 2015 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
Can you fix the video display on a HP Touchsmart 300-1003?
how you try to attach an external monitor if you have a VGA, HDMI port? if it works the problem is the LCD but I don't think the air flow caused the problem since these all in one are even very difficult to open. Try to correct this blockage but try the first suggestion.
Jul 13, 2014 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
Hp compaq laptop how to restore to factory default?
Go to Start/All Programs/HP Tools/HP PC System Recovery
If this doesn't work then try pressing the F10 key multiple times during the bootup to access the recovery console.
If this still doesn't get things fixed then you need to re-install XP
If this answer helped you then do visit my blog TECHAMY
Jul 09, 2012 | HP Computers & Internet
Fix computer screen doesn't fit
Change the screen resolution on the desktop in the control panel. Click Start/Control Panel or Start/Settings/Control Panel and look for Desktop or Appearance and Personalization. Open the desktop and change the screen resolution on the settings tab.
You can also open the desktop by right clicking on an empty space on the desktop and select properties.
Jun 02, 2012 | HP Computers & Internet
How do I fix the constant flickering of the screen?
Take the lcd assembly apart, and disconnect and reconnect the ribbon cable on the back of the lcd. Also disconnect and reconnect the other end of that cable. If that doesn't fix it, disconnect and reconnect both cables that go to the inverter board (it's the small circuit board inside the lcd assembly- example in picture below). If still no good, then you probably need a new inverter board. Call HP and get a phone number for one of their parts suppliers. Inverter boards are cheap ($10-$20). Even if it doesn't fix it, it doesn't cost much to try. If still no good, then take it to a service shop.
Hope this helps!
Joe
Mar 22, 2012 | HEWLETT-PACKARD HP Pavilion G61b70us...
I let my reader PRS-300 connected to pc all night to charge the battery, but now it doesn't turn on...what i can do??? and i tried to connect to pc again to see what happened, but not even the red...
Hi vailzamorta!
You can try to do a "Soft Reset" on the Reader. Do not worry, this will not affect your ebooks =)
1. Disconnect the reader from the computer
2. Hit the Reset button at the bottom of the unit for 3 seconds with a paper clip
3. Slide the power switch at the top of the eReader
4. The screen will blink and show opening book.... allow the reader to load
Just in case here are some other steps to try in case this does not make any difference
http://digialreader.freeforums.org/solution-for-frozen-sony-reader-t10.html
GoodLuck!
eBookBoy
Jul 26, 2011 | Sony Reader Pocket PRS-300
Ive just bought a hp 620 notebook pentium dual core t4 i got it all set up and running an hour later the screen was all fuzzy and rolling and cant get anything please can you tell me what is wrong ?
The video driver of your laptop may be failing. You just need to update it if restarting the computer doesn't fix it. Check HP website and download the on compatible with your operating system.
If this doesn't work, try to check BIOS (by pressing F2..F10..depends on what key is designed for it..before windows loads up) if you still have the same problem. If yes, get a replacement, the LCD inverter or LCD cable may be faulty. But if this will not appear in the BIOS, the video card may be faulty.
Hope this helps.
Jun 03, 2011 | HEWLETT-PACKARD 620 XT964UT Notebook PC
My new touchsmart 300 pc will not work
Contact HP they have a special driver.
Tell them to provide you with the touch screen drivers.
Install it and check if it works.
May be its the graphics driver.
May 29, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Jan 09, 2009 | HP Pavilion 7965 PC Desktop
Broken screen
THE SCREEN IS A COSTLIEAST ONE , SO IT HANDLE CAREFULLY.FIRST TO OPEN SCREEN TO UNSCREW AND THEN REMOVE DISPLAY WIRE(STRIP).BUY NEW ONE FIX ON THE SAME TYPE OF MANNER . THE COST OF DISPLAY AROUND 300$.
Jun 26, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
