Question about Trukfit DA WURL TANK TOP MENS Shirts and Tops Tank Tops Blue XXL
Whats the measurements for jrs tank tops by Wurl?
Where is the fuel pressure sensor located on 2000 GMC Sierra p/up 5.3
They didn't have a fuel pressure sensor in 2000.... are you referring to the fuel tank pressure sensor? That sensor measures the vacuum/pressure in the fuel tank and is related to evaporative emission control. That sensor is externally located directly on top of the fuel pump on top of the fuel tank. It has a 3-wire connector plugged into it.
Sep 01, 2013 | 2000 GMC Sierra
What can I replace a rheem 71-30S 120v 30 gallon water heater with thats the same size, not larger in dimensions
Measure what you got, and add comment.
Measure across the top.
And then measure the height.
Then I will check resources and find close match.
Otherwise, the last guy wanting a small water heater bought his at local Lowes and it was small enough
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 13, 2013 | Water Heaters
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
2:3 of 60
First figure out how many Jrs. and Srs. there are.
With a ratio of 2:3, to find one part: 60/5 = 12.
2 parts = 24 Jrs. and Srs. and 3 parts = 36 Soph. and Fresh.
Now to find out how many Jrs. use the second ratio of 1:2. One part would be 24/3 or 8. So there are 8 Jrs. and 16 Srs. on the team.
Thanks for using Fixya.
Nov 05, 2009 | The Learning Company Achieve! Math &...
Where do you put the soap cleaner, does this go
The cleaning solution goes in the top tank. Fill top tank with hot water first, then add the cleaning solution. That way it doesn't foam up. The tank lid is also a cup to measure how much solution you put in. Usually fill to top line. Make sure when you put tank on machine it snaps in place. if you have a manual, refer to it for instructions if you need to.
Hope this helps.
Sep 14, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The measurement of gasoline , Shows the measurement of the wrong
Since all the gauges in a town car are electronic, you may have to completely fill and empty (not to where the car won't run) the fuel tank a few times to recalibrate the new float. (if that's what you replaced) If you did not replace the float, that is what is most likely causing the problem.
Jun 08, 2009 | 1991 Lincoln Town Car
Why cant I see a planet on a cc-jrs telescope
What eyepiece size are you using and what planet are you targeting? Jupiter is usually a good starter after you've practiced on the moon.
Aug 07, 2008 | Galileo 700 x 60 Refractor Telescope
Trukfit DA WURL TANK TOP MENS Shirts and Tops Tank Tops Blue XXL Logo
70 people viewed this question
Top Trukfit Clothing Experts
ray gallant
Da Doc
Bill Boyd
Are you a Trukfit Clothing Expert? Answer questions, earn points and help others
