Question about Pioneer AVIC-F700BT Car GPS Receiver
Why does Sound drops out after startup - Pioneer AVIC-F700BT Car GPS Receiver
Why my laptop windows 8 dont give sound when it starts?
By default windows 8 startup sound is disabled. To enable it go to search, type "Sound" go to "Sounds" tab - click "Windows Change Theme" - check the checkbox "Play Windows Startup sound" and select the sound you like.
Jul 31, 2014 | Computers & Internet
How can I turn off startup sound
StartUp sound is good for your system because it will tell you something but if you want to turn it off then try to
press the F10 key on your keyboard to mute you Mac before rebooting or use any app for it. if you want to know the importance of startup sound than follow Apple Support Number .
Jul 15, 2014 | Apple MacBook Air
2009 Audi A4 loud engine startup sound & shake
probly need new motor mounts--also a dirty throttlbody can hav the same effect--u can cleanit with a nonchlorinatd solution
Oct 31, 2013 | Audi A4 Cars & Trucks
No statup sound in system
Restore the Startup Sound in Windows 7 If you decide that you want the Windows Startup back on your computer, just follow the steps explained above, but this time, check the "Play Windows Startup Sound" checkbox and click OK. The change is saved immediately, and turns back on this sound for the next time you reboot your PC!
Sep 26, 2010 | HP Compaq dx6100 PC Desktop
Black screen after startup
drop it on the ground lol
Jul 11, 2010 | Computers & Internet
No sound card driver no sound audio
Try this:
Go to Start->Settings->Control Panel->Adminstrative Tools->Services
Then locate in the list of services "Windows Audio". Open this service
If this service is showing with a Startup type set to Disabled then Select "Automatic" from the drop down list then hit apply. Then click the "Start" button.
If this service is showing with a Startup type set to Manual then Select "Automatic" from the drop down list then hit apply. Then click the "Start" button.
Next Go to Start->Settings->Control Panel->Sounds and Audio Devices then select the Volume Tab then put a tick in the box marked "Place Volume Icon in the Task Bar" then click apply.
With a bit of luck and following wind you should now have your sound restored.
Good luck
Apr 20, 2010 | HP (400745-001) Sound Card
Disk was dropped while active, now it makes a tone when attempting to startup
Hello
Thank you for using
FixYa for your problem
Sorry but dead now, is it a clicking type of sound
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Ximeta Technology NDU10-160 NetDisk 160MB...
I have a Swintec 8012. From time-to-time (and
The silver shaft that the printwheel carrier moves on may be dry. Turn the power off..apply a few drops of oil to a clean rag and wipe the shaft. so this twice. also put a small drop of oil on either end of the shaft..this may help.
Squipps
Oct 05, 2009 | Office Equipment & Supplies
Yamaha DSP-A1 sound drops at startup
In the manual it says switch off leave for 30 seconds and switch back on .
Aug 07, 2009 | Yamaha DSP-A1 Receiver
Plasma no picture, fades to black from startup logo
UPDATE:
I finally isolated the problem, the problem has to do with the Y SUSTAINER BOARD not receiving enough/necessary voltage when turned on, while initially thinking it was just the yboard was the problem, i replaced the Y sus board with no success, with only further diagnosis, i discovered the board voltages coming from the powersupply, there are 5 voltages that relate to the Y sustainer board, VA, VSC, VS, VE, VSET. they all supply a certain voltages that all have to be supply the correct voltage in order for the y sustainer board to be working, well guess what, the VA line, which for my set needs 70volts, which upon startup quickly drops from 75volts to a jumpy 8.5-9.5 volts, which of course is nowhere near the 70 volts needed, so this quick drop in voltage is directly related to the screen fade upon startup, i found the problem now the real problem is finding a replacement power supply. hope this helsp anyone with similar issues.
Mar 02, 2008 | Dell W4201C 42 in. Plasma HDTV
Pioneer AVIC-F700BT Car GPS Receiver Logo
20 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
