Question about SK Paslode Sk312 Framing Nailer O`ring Parts Kit
Where can I get a trigger valve for Paslode sk312
2 Suggested Answers
  • 2976 Answers
SOURCE: I was given a Paslode Sk312 so what type and size
The nail gun you mention was put on the market in 1973 and it is very limited. It can only handle a few different nails without retooling. That means, you will have to have it modified to work with nails other than what it was originally designed for.
Posted on May 19, 2010
Testimonial: "do you know what kind of nails I can use and where can I buy them ?"
Jammed
Make sure that you are using the correct angle nails and head type,,,some use clipped head , others full head,,,others offset full head
Feb 09, 2013 | SK Paslode Sk312 Framing Nailer O`ring...
The cylinder head ring has broken twice
are you oiling/greasing the oring when you are putting in a new one?
Sep 24, 2012 | SK Paslode Sk312 Framing Nailer O`ring...
Paslode cordless framing nailer doesn't fire
check date on bottom of fuel canister, fuel goes bad
Sep 17, 2012 | SK Paslode Sk312 Framing Nailer O`ring...
Paslode 350 Framing nailer trigger does not fire.. Has worked until today, has the correct pressure, but the trigger feels dead.
make sure the safety is not bent what you can try and be careful is remove ALL nails and plug the tool into the air supply, find a small screwdriver and holding the nose up off work use the screwdriver to depress the trigger valve, if it works then you have a safety issue, if not then you have a trigger valve issue. Let me know if you need more help
Jan 18, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode compact nail. the firing pin will not return
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 19, 2010 | SK Paslode Sk312 Framing Nailer O`ring...
I was given a Paslode Sk312 so what type and size nails can I use and where can I buy them. I was told I cant use the round head nails unless I have it re tooled what ever that means
May 19, 2010 | SK Paslode Sk312 Framing Nailer O`ring...
Warning ligt flashing
please check your model number , the paslode sk312 does not have a warning light since its a air powered gun
Feb 14, 2010 | SK Paslode Sk312 Framing Nailer O`ring...
I have a Central Pneumatic air nailer that has the seal crumbling. Seems to be a problem. Where can I get the kit to repair it? Thanks
You can call Harbor Freight and see if they have the repair kit available. 1-800-444-3353. Sometimes they change the models and will not have parts available. It may take up to 6 weeks for you to get your parts if they are available. Be prepared to wait. The parts will not be expensive. Depending on which seal you are talking about, you may have to order an assembly. I am directly talking about the trigger seal. This part seems to crumble the most. If you require more information please post additional information about your model and the seals you are requiring.
Sep 28, 2009 | SK Paslode Sk312 Framing Nailer O`ring...
Paslode framing nailer won't shoot
Take 4 bolts off of head . Clean and lube head valve with air nailer oil. Not wd40
Apr 05, 2009 | NRS Paslode 501000 Powermaster Plus...
SK Paslode Sk312 Framing Nailer O`ring Parts Kit Logo
60 people viewed this question
Top SK Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a SK Air Tool and Compressor Expert? Answer questions, earn points and help others
