Question about Hayward H-series Electronic Gas Pool Heater H400
Hayward h series Bo problem
With pimps on heater in Bo mode but will not fire. Gas on.
  • Hayward Master
  • 1,631 Answers
BO = "By-Passed Operation"
This will show, when ever the heater is programmed, or wired, into an automation system. It means that the automation system has control of the heater, this was done by either programming, flipping a dip switch, or via a logic jumper. All depending on model of heater.
Posted on May 25, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Hayward Master
  • 1,448 Answers
Make sure you have adequate gas pressure
Posted on May 26, 2014
jgwhomeequip
  • 1902 Answers
SOURCE: the pilot won't light, don't hear gas going through the valve
Yes when you do not hear any gas it is a thermocouple problem and it needs to be replaced.
Posted on May 22, 2009
  • 4 Answers
SOURCE: hayward pool heater h series
the issue is a broken baffle in the system. there is a baffel that directs water into the heat exchanger and back out into the system. The welds that hold the baffel in place have broken off. It can be repaired if you take the unit to someone with a mig welder and have them re-weld it (muffler shop, mechanic?). there needs to be a weld on both sides. You can see the baffel if you remove the unit and look down the inlet and outlet tubes.
Posted on May 25, 2009
SOURCE: Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Posted on Jun 13, 2009
  • 128 Answers
SOURCE: same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Posted on Aug 23, 2009
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
Had a power outage yesterday now heater won't ignite. No error codes.
bo = 'Bypassed Operation'
heater is now controlled via your automation system.
Create a heat call, turn solar off if active.
Heaters should be set to auto on.
Mar 07, 2015 | Hayward Pool Products Hayward Universal...
BO code heayer keeps cycling on and off
check to see if proper gas pressure call gas company give them added total thems all your appliances use they probably will give you a bigger meter then everything will run efficiently
May 24, 2014 | Hayward H-series Electronic Gas Pool...
Have a bo code heater keeps cycling on and off
BO code is bypass operation. It means that it is set to operate with an external controller. Things like Aqualink, Aqualogic, Intellitouch, EZ-Touch are all types of automation / external controllers. They have their own temperature sensor and allow remote control operation. To truly find the nature of your issue. I'd start by taking it out of bypass operation and see if the unit fires by itself ( without automation hooked up to it ). The fault may lie with the automation system. You never know.
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400 error code bo
This error means "Bypass Operation". On the back of the control module there are some "dip switches". They have an on or off position. Check switch number 2. Make sure it is in the "off" position. The "on" position is for a remote thermostat.
Jun 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
My service light is on and I have a bO code. The heater will run some times, more time than not it will not run. Thanks Dave
The bO code is a normal code. It stands for bypass operation and just means that the heater is wired into an automatic controller such as a jandy or aqualogic. If there is a call for heat and the heater doesn't fire, you should be getting an error code. It may take several (3 or so) attempts at firing before you will get the code. HTH
May 15, 2010 | Hayward H400idl2 400,000 Btu Low Nox...
My pool and spa heater is not working diplays service codes bo and AO
MAKE SURE THE FILTER IS CLEAN THAN THE TEMPETURE SENSOR MAY BE BAD, CLEAN THE FILTER FIRST
Oct 10, 2009 | Hayward H Series Pool & Spa Heater 400k...
Same problem pool heater shows hayward pool heater bo error
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H400 Logo
526 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
