GoVideo DV2130 DVD Player / VCR Combo
Problem for GoVideo DV2130 DVD Player / VCR Combo
When I put in a
By win7 on Jun 23, 2009
When I put in a disc and press olay it says'no disc' I have tried several different discs ALL THE SAME
Comments:
Jun 23, 2009
- Well that doesn't help a whole lot. Can't really afford a new one right now. Any other suggestions Win.
Solution #1
posted on Jun 23, 2009
Not Rated)
Azum
Rank: Guru
Rating: 85%, 291 votes
it means that DVD need to be serviced and also is the posibility that is laser head have gone dead... replacing would make it work... regards
Solution #2
posted on Jun 24, 2009
Not Rated)
praky16
Rank: Wiz
Rating: 80%, 567 votes
the most common problem is that ur dvd lense would have gone faulty. u should first clean the lense of ur player.To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter....
Memorex makes a disc cleaner that uses brushes. Assuming that most hardware should just have dust and shouldn't really need solvents, this should be adequate.
or u can use isoproponol alcohol on a cotton bud,one wipe with the slightly damp end then a quick wipe with the dry end
if ur lense cleaning solution didnt solve ur problem means u can try this alternate solution also the head has lost it's "tracking" over the years (DVD players sadly do not last forever).u can purchase a new head.
i have given u the possible solutions if nothing seems to be working for u. just u can move on with ur new dvd unit. it will be a perfect move by u...
thank u..
rate me
Popular Solutions for GoVideo DV2130 DVD Player /
Questions and Unsolved Problems for GoVideo DV2130 DVD Player /
Do you recommend GoVideo DV2130 DVD Player / VCR Combo?
Answer
Answer
is there an bios update for go video dv2130 player dvd/vcr
Answer
cannot get dv2130 to display on TV while playing
Answer
1.HOW TO COPY VHS TO DVD. 2.DVD SKIPS OR STOPS WHEN PLAYING. I kept requesting replacement DVDs and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
