Question about Video Game Consoles & Games
97 seadoo cuts in and out when you get to about 40 miles per hour whats wrong with it?
JustJeeps
  • 74 Answers
SOURCE: Won't go past 40 miles per hour
no not muffler problem could be bad gas or TPS sensor how many miles you have on it?
Posted on Nov 30, 2008
  • 39 Answers
SOURCE: Won't accelerate past 40 miles per hour
these jeeps did have a small problem with the tp sensor. i would also have the back pressure of the exhaust checked to see if you have a catalytic converter choked up.
glamarre82
  • 140 Answers
SOURCE: speedometer sticks / jumps
Yeah you may need a whole new dashboard because the whole panel circuit for may be messed up.
Posted on Aug 04, 2009
  • 87 Answers
SOURCE: my prelude wiil not accelerate past 30 to 40 miles per hour
Generally the symptoms say the catalytic converter is clogged, you can't get any air out so you can't pull any air in, and the age of the vehicle says so too. Look and see if it has ever been replaced.
Posted on Nov 14, 2009
Testimonial: "sounds like the problem, we will check it out and post the results, Thanks, Stacy"
  • 2309 Answers
SOURCE: I HAVE A 2002 E350
these systems are fairly complicated and not easily diagnosed best to have it properly scanned with a real time scanner
Posted on Apr 12, 2011
If 360 km per hour is equal to 40 miles per hour, please show me how to calculate using formular
360 km/hr is NOT 40 miles/hr.
1 mile is about 1.6 km
To go from km to miles, multiply by 0.62
To go from miles to km, multiply by 1.6
Kilometers per hour to Miles per hour
Feb 23, 2017 | Cars & Trucks
Vibration when going about 40 to 50 miles per hour feels like whole underneath is vibrating
IF you have rear wheel drive then check the u-joints for wear/loose. Check slip joint for wear . Check rear engine mount is in good condition. Check wheel balancing
Nov 25, 2013 | 2006 Saturn Vue
I put 2,720.00 worth of work into my 97 Pontiac grand am. Engine light is flashing the car sputters and might get up to 40 mile per hour I took it out on the road again and got it up to 75 mile per hour...
Sounds like who ever did the work on your car needs to go back and check the plug wires to see if they are going to the right plugs. and check the fuel filter, and fuel pump pressure. I would also check the Catalytic Converter to see if it is stopped up, if so replace it. Check the throttle position sensor with an ohm meter, if bad replace it. Check the oxygen sensors as well. I am running out of Ideas, so I hope this helps.
Aug 10, 2013 | 2001 Pontiac Grand Am SE
2005 545i bmw sputtering at 40 miles per hour
So, here's what you have to do - it's a frikkin tranny reset!!
Drive in manual mode M5 for 5 minutes at over 60MPH, then switch it to M6 for 1 minute, then back to M5 for 2 minutes, then back to auto.
Note: the car is going to sputter continuously when you have it on M5 for the 5 minutes.
That was it - drove around for 30 minutes afterwards and no issues what so ever!! Unbelievable!!!
Sep 05, 2012 | BMW Cars & Trucks
My 97 accord would only go 30 miles per hour but the rpm s were going to the red line. the engine was reving on it's own. what could be wrong
Jennifer,
The problem is in your transmission [automatic transmission] or clutch [standard transmission] Check the level of the fluid in an automatic transmission. Check for proper free play in the clutch of a manual transmission.
Dec 01, 2011 | 1997 Honda Accord
Starts cutting out over 40 to 50 miles per hour
Clean or replace EGR valve..........Hope this help.
Aug 14, 2010 | 1997 Oldsmobile Bravada
My 1999 88 LS has a vibrating sound when driving from 35-55 miles per hour and is loudest when going 50 miles per hour. I had the tires replaced and the car rebalanced but the car still makes a vibrating...
check the axle shaft assy,an excessive joint angle due to incorrect toe-in or trim height,,,,,Wm or damage inboared or out boared joint,,,,,,,A sticking spider ( tri pot joint)
Jul 03, 2010 | 1999 Oldsmobile 88
Speedometer sticks / jumps
Aug 02, 2009 | 1998 Nissan Frontier
Nov 24, 2008 | 1999 Jeep Wrangler
Video Game Consoles & Games Logo
69 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
