Question about Cycling
How to install Novara Expanding Seat Bag - Cycling
2008 ford f-350 passenger air bag flashes 1-7 code than stays on when truck is started.What does the code mean and can the code be reset without tearing air bag out of truck?
If a SRS fault exists, the RCM sends a message to instrument cluster module to flash a coded sequence which is called a lamp flash code (LFC) on the air bag warning indicator. Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle. In addition to the self-test at start up, the RCM continuously monitors all of its external and internal circuitry for faults.
While the LFCs are an indication of a general concern in the supplemental restraint system (SRS), the DTCs are more specific. The DTCs can be retrieved from the RCM with a scan tool via the DLC.
DTC a c LFC b Description Action To Take - Continuous Lamp The Air Bag Warning Indicator is Illuminated Continuously (RCM Disconnected or Inoperative, Loss of Battery Feed or Loss of Signal Ground) Go To Pinpoint Test A . B1048 c - Passenger Side Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test B . B1049 c - Passenger Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test C . B1054 c - Driver Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test D . B1057 c - Driver Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test E . B1231 13 RCM Crash Data Memory Full INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) and Inspection and Repair After a Supplemental Restraint System (SRS) Deployment in this section. B1317 Continuous Lamp Battery Voltage High REFER to Section 414-00 . B1318 Continuous Lamp Battery Voltage Low REFER to Section 414-00 . B1342 24 RCM is Faulted INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) in this section. B1871 25 Passenger Air Bag Deactivate Module Fault Go To Pinpoint Test F . B1884 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Circuit Failure Go To Pinpoint Test G . B1890 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Short to Battery Go To Pinpoint Test H . B2292 33 Restraint System - Seat Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test I . B2292 34 Restraint System - Seat Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test I . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault Go To Pinpoint Test K . B2434 53 Driver Seat Belt Buckle Switch Circuit Short to Ground Go To Pinpoint Test L . B2435 53 Driver Seat Belt Buckle Switch Resistance out of Range Go To Pinpoint Test M . B2477 54 Module Configuration Failure This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2607 57 Harness/Configuration Mismatch This DTC indicates the RCM is configured incorrectly. CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. B2691 53 Seat Belt Buckle Switch Circuit Fault, Front Driver's Side Go To Pinpoint Test N . C1414 29 Incorrect Module Design Level VERIFY RCM part number is correct for vehicle.
CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. U0100 14 Lost Communication With ECM/PCM REFER to Section 418-00 to diagnose the communication concern. U2023 14 Fault Received From External Node REFER to Section 418-00 to diagnose the communication concern. U2050 14 No Application Present This DTC indicates programmable module installation (PMI) has failed. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. a DTC: Diagnostic trouble code, retrieved using scan tool.
c Cross-link DTCs will be retrieved in pairs to identify the cross-linked components.
b LFC: Lamp fault code, flashed on air bag warning indicator.
Apr 18, 2017 | Ford Cars & Trucks
Where is the seat senor that is connected to the air bag light located on a dodge caravan 2007 3.3 liter ?
its not a seat sensor, most likely you got mosture in the body control module
Oct 09, 2015 | 2007 Dodge Caravan
Where is passenger side air bag relay 2007 MKZ
There is no relay for the passenger side air bag . What seams to be the trouble ? There is possibly a code set in the air bag control module .
Air Bag and Safety Belt Pretensioner Supplemental Restraint System (SRS) The air bag supplemental restraint system (SRS) is designed to provide increased collision protection for front seat and second row outboard occupants, in addition to that provided by the 3-point safety belt system. Safety belt use is necessary to obtain the best occupant protection and to receive the full advantage of the SRS.
This vehicle line contains dual stage deployment (advanced restraint system) driver and front passenger air bag modules. These vehicles are also equipped with driver and front passenger safety belt retractor pretensioners. These vehicles can also be equipped with optional side air curtains that deploy from the A-pillar to the C-pillar upon a side impact. Vehicles with optional side air curtains are also equipped with seat side air bag modules in the front seats.
Side air curtains deploy from the headliner, protecting the first and second row outboard occupants during a side impact. Seat side air bag modules deploy from the outboard front seat backrest upon a side impact. In addition, a front impact severity sensor is mounted to the lower radiator support, a seat position sensor is mounted to the driver seat and a usage detection switch is added to the front driver and passenger outboard buckles. If equipped with optional side air curtain modules and seat side air bag modules, there are an additional 4 side impact sensors.
Vehicles are also equipped with an occupant classification sensor (OCS) system as part of the front passenger seat. The OCS system includes 2 OCS rails and an OCS module.
Passenger Air Bag Deactivation (PAD) Indicator
The passenger air bag deactivation (PAD) indicator is a visual indicator used to inform the front seat occupants of the passenger air bag deactivation state. The PAD indicator is a stand-alone lamp installed into the vehicle instrument panel in a position visible to each front seat occupant.
The restraints control module (RCM) controls the state of the PAD indicator through a direct hardwire connection, based on information provided by the occupant classification sensor (OCS) system. The PAD indicator is lit to indicate the passenger air bag module is disabled. An exemption to this is when the front passenger seat is determined to be empty and passenger safety belt buckle unbuckled, and therefore indication of a deactivated passenger air bag module is not necessary. In all other cases, the PAD indicator is unlit when the passenger air bag module is enabled.
When the ignition switch is in the ON position, the PAD indicator prove-out period is initiated by the RCM. The RCM briefly activates the PAD indicator to prove-out the indicator function and verify to the front occupants correct functional operation of the PAD indicator.
The PAD indicator will be lit/unlit within 1.0 to 1.5 seconds of a change of state from the OCS system.
When an OCS system fault is present, the RCM defaults the passenger air bag module to the last valid state received from the OCS system until the ignition switch is turned OFF. If the OCS system fault is still present when the ignition switch is turned ON, the RCM defaults the passenger air bag module to enabled regardless of the size of occupant in the front passenger seat. The PAD indicator will be unlit. For information on the OCS system, refer to Occupant Classification Sensor System in this section.
The following table indicates the passenger air bag status and the PAD indicator status based the size of the front outboard passenger occupant.
Oct 04, 2015 | 2007 Lincoln MKZ
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
In need the instructions
This is a seat post mounted bag, with attachments for the rails (2) on the bottom of the seatpost.
1. The straps going over the top of the bag will have to come apart. Removing them from the loop they pass through before re-attaching with the velcro.
2. Undo the straps and then feed them over the metal seat rails.
3. Re-assemble the straps in the same manner they were before and loosely attach the velcro. You will later tighten up the tension on these straps to snug the bag up under the seat.
4. Attach the velcro strap on the posterior of the bag to the seatpost.
5. Now the bag should be supported by the seat post strap and the seat rail straps (2). Hanging loosely and oddly from the seat area.
6. Tighten/snug the straps from step three, so the bag is drawn up against the bottom of the seat. Try adjusting all the straps on the bag until the bag appears to sit well under the seat.
7. DONE
Jan 05, 2013 | Avenir Bigmouth Seat Bag
Schwinn seat bag....how to install A picture of correct installation would be helpful as straps don't seem to go anywhere
The bags are slightly different but the pictures should give you the idea.
http://www.cambridgebicycle.com/design/accessories.htm
http://triathlons.thefuntimesguide.com/2009/03/cycling_gear.php with a blowup.
The straps loop over the seat rails then rejoin under the bag; the front loops go around the seatpost.
Search engines find everything.
Jun 19, 2011 | Schwinn Bicycle Seat Bag Black Bike Under...
Bicycle recommendations?After many many years of not owning a bike, I've decided I want to get one, not only to keep in shape, riding around town, and on trails (gravel, not hard-core off-roading), but...
I have the Cannondale T2000, best bike I have ever owned.
http://www.cannondale.com/bikes/06/CUSA/model -6TR2.html
If you have an REI store near you, they have a great bicycle shop, and carry the brand Novara, here is a little article about Novara:
http://www.rei.com/rei/gearshop/novara/story. html?cm_re=NovaraHP*Top*Novara_Story
If the Cannondale is a little out of your price range, my second recommendation is the Novara Safari, which has a really nice handle bar configuration.
http://www.rei.com/online/store/ProductDispla y?storeId=8000&catalogId=40000008000& productId=47968753&parent_category_rn=450 0921
Both of the above recommended bicycles are considered touring bikes or hybrids. They are very comfortable and easy to use.
Whatever you decide on, make sure you get something with trigger shifting, it really makes a difference for ease of operation and unlike twist shifting, which you accidently knock your bike out of gear when you hit a small bump.
Also, make sure you get fitted for a bike at a bike shop. It makes a world of difference to have your bike properly fitted for your frame. A good bike shop will offer to fit you, then suggest you come back in a couple of weeks for adjustments and to tighten the brake cables.
This is really important, make sure you have a proper fitting helmet. My helmet saved my life. I can not tell you how important it is to have a helmet that fits properly and that each time you get on your bicycle you check the straps and make sure that your helmet is secure.
Dec 21, 2010 | Cycling
Where is the passenger airbag on and off switch?
The passenger air bag is turned on or off with sensors in the passenger seat and the seat belt.
The sensors disable the passenger air bag if the seat is unocupied or if a car seat or booster chair is in use and installed properly.
Jul 13, 2010 | 2008 Ford Focus
Front headrest, ford focus
Seat Backrest — Front adobe.gif Printable View (404 KB) Disassembly
All vehicles
ani_caut.gif WARNING: Always wear safety glasses when repairing an air bag supplemental restraint system (SRS) vehicle and when handling an air bag module. This will reduce the risk of injury in the event of an accidental deployment.
ani_caut.gif WARNING: Never probe the connectors on the air bag module. Doing so can result in air bag deployment, which can result in personal injury.
ani_caut.gif WARNING: Front seat back trim covers installed on seats equipped with side air bags cannot be repaired, they are to be replaced. Cleaning is permissible.
ani_caut.gif WARNING: To reduce the risk of personal injury, do not use any memory saver devices.
NOTE: If a seat equipped with a seat mounted side air bag and/or a safety belt pretensioner (if equipped) system is being serviced, the supplemental restraint system (SRS) must be depowered.
NOTE: The air bag warning lamp illuminates when the RCM fuse is removed and the ignition switch is ON. This is normal operation and does not indicate a supplemental restraint system (SRS) fault.
NOTE: The SRS must be fully operational and free of faults before releasing the vehicle to the customer.
  1. Depower the SRS. For additional information, refer to Supplemental Restraint System (SRS) Depowering and Repowering in the General Procedures portion of Section 501-20B.
  1. Remove the head restraint.
  1. Remove the head restraint guides.
    • Using a suitable screwdriver, depress the locking tang.
May 31, 2009 | 2004 Ford Focus
Airbag light is on - 2003 Tiburon
section_closed.gif 2003 HYUNDAI TIBURON Recall ID from NHTSA: 02V290000 Auto Recall Date: NOV 05, 2002 Vehicle Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY Model Affected TIBURON Estimated Vehicles Affected: 7382 Recall Details Auto Recall Date: NOV 05, 2002
Vehicle Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY Estimated Vehicles Affected: 7382 Model Affected2003 HYUNDAI TIBURON
2003 Hyundai Tiburon Defect Summary:ON CERTAIN PASSENGER VEHICLES, THE DRIVER SEAT BELT BUCKLE WIRING COULD BE DAMAGED BY INTERFERENCE WITH THE DRIVER SEAT CUSHION HEIGHT ADJUSTER MECHANISM.
Defect Consequence:DAMAGED DRIVER SEAT BELT BUCKLE WIRING COULD CAUSE THE SEAT BELT WARNING LAMP OR THE SUPPLEMENTAL RESTRAINT SYSTEM (SRS) AIR BAG WIRING LAMP TO ILLUMINATE. IT COULD ALSO CAUSE THE AIR BAG FUSE (CAVITY NUMBER 5) TO OPEN, PREVENTING AIR BAG DEPLOYMENT. NONDEPLOYMENT OF AN SRS AIR BAG IN A CRASH WHERE AIR BAG DEPLOYMENT IS WARRANTED COULD INCREASE THE RISK OR SEVERITY OF INJURY IN A CRASH.
Remedy:DEALERS WILL INSTALL A NEW DRIVER SEAT BELT BUCKLE, IF NECESSARY, AND WILL PLACE A PROTECTIVE COVER OVER THE DRIVER SEAT BELT BUCKLE WIRING TO PREVENT DAMAGE FROM OCCURRING. OWNER NOTIFICATION BEGAN ON MARCH 24, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HYUNDAI AT 1-800-633-5151.
Notes: HYUNDAI MOTOR COMPANY 056
Dec 07, 2008 | 2003 Hyundai Tiburon
Cycling Logo
42 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
