Question about Honeywell VS820A1054 Single Valve Standing Pilot 3/4 NPT x 3/4 NPT
Flame adjustment which adjustment screw changes the flame height
How to adjust oven burners to lower it and to turn up top burners
Really you should get a registered gas fitter to do this especially with the oven.
There is a small set screw behind the plate that covers the control knobs. Light the burner, turn the knob to its lowest setting and then use the adjusting screw to set the minimum flame height. The flame must be robust enough that it can't blow out when you open a door or window and create a draught.
Oct 03, 2015 | Kenmore Kitchen Ranges
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Gas fire place flame to low, do you have a schematic to increase the flame ?
Generally, whether it's a Vent-free or Vented fireplace, lower than normal flame height is caused by 3 things: Low Gas pressure; The air shutter control valve is clogged or needs adjusting; The burners need cleaning.
I haven't seen a unit in the past 10 years, that has a flame height adjustment, other the flame height control knob, that's part of the control assembly. Have you checked that, to see what height it's turned to low?
Perhaps, if I knew who the manufacturer was and the model number, I could be of more help to you.
Mar 15, 2011 | Honeywell Heating & Cooling
Pilot flame does not reach the ignite point(VENTLESS SPACE HEATER
The pilot jet may be contaminated with with oxidized metal particles; wipe its 'nose.'
If that doesn't help, most of the regulators on gas appliances have a small screw to adjust the flame length/height.
Dec 02, 2009 | All-Pro SPC-20 Heater
Just turning on heater for first time this season. Thoroughly cleaned heater. Pilot is fine, but when I turn the knob to increase flame, it's a very week blue flame and then eventually just clicks off....
Hello there:
where the line goes into the heater there should be a adjustment screw that you can adjust the flame height 4 to 6 inches is a good height for these units but dont overdue it cause the flame will turn a totally different color and this will be too much ok?
hope that this is very helpfull for you
best regards michael
Oct 23, 2009 | Desa International GWP30T Heater
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
Jan 26, 2009 | Amana AKS3040 Gas Cooktop
Bakers pride pizza oven
does it light then immediately go out? if yes, usually you have to hold in a button to allow gas to flow while you light the pilot, and hold this button until the therm0-couple is heated with the pilot flame. If the thermo-couple is not sufficiently heated and you let go of this button, the pilot light will go out as the safety circuit thinks there's no flame and unburned gas is entering the oven.
The other thing you could do is adjust the height of the pilot flame... there's usually an adjustment screw near the button described above which will allow you to adjust the height of the flame. Make the flame just big enough to guarantee that it keeps the thermo-couple hot AND that it can light the oven without being blown out.
Good luck.
Apr 21, 2008 | Ovens
Dyna Glo 95-c flame height
check your air passages for a blockage. the wick just aids in burning your fire.
Nov 03, 2007 | Heating & Cooling
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Honeywell VS820A1054 Single Valve Standing Pilot 3/4 NPT x 3/4 NPT Logo
12 people viewed this question
Top Honeywell Electrical Supplies Experts
Dennis Boxerman
 Kenneth
Kenneth
obsteiner
Are you a Honeywell Electrical Supply Expert? Answer questions, earn points and help others
