Wansa 24"a350 suply 12 volt o.k no led show but 5 volt ok no in st.by
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Caps on the psu. youtube how to repair psu on a tv
Posted on May 17, 2014
Troubleshooting
Tv has no picture, standby led light, output voltage from spms is 17,17,5,5 instead of 12, 12, 5, 5. Signal on/of from main board is ok, 3 volts. I do not know whether the voltage 17,17 culprit or it is ok. In the dark I can not see any pictures
May 27, 2013 | Philips 220TW9FB 22 in. LCD TV
Hou you can make a stand alone 12 volt suply
Take two 6 volt batteries and put them in series to one another, and/or eight 1.5 Volt cells in series.
Mar 24, 2013 | Dell DPS-312AB Power Supply Server Power...
I have a Phonic Helix Board 24 firewire MK2 When i open it all the peak led stays open I think the power suply is busted I need an expert
The power supply uses three, 3 terminal regulator chips. You should find +/- 15 volts and +5 volts DC from those. There are two fuses, one for each polarity. If one of those is blown, that would cause the problem and one would need to find WHY it blew before replacing it.
You need to find a competent electronics repair person.
Nov 02, 2010 | Phonic Helix18fw 18 Channel Mixer with...
How do your fix your television if it has no power and wont come on
hi
there are no magic solution you have to go step by step gotta check if power suply is running with
3-5-12-24 volt out put witch I supect is the defect part and go from there
Sep 28, 2010 | Protron PLTV3250 32 in. LCD Television
2003 Silverado one ton shows -11.7 volts at brake lamp connections. Truck light work ok but the trailer brke light are leds and they don't handle the -11.7 volts.
Hello! Place a 1/4 watt, 50 ohm resistor in series with the +12 battery feed to the trailer LED brake lights...Each LED drops 3.6 Volts...You can run a maximum of 3 LED's per resistor...If you have more than 3 LED's run them in parallel with each set of 3...Each run of 3 requires it's own 50 ohm resistor...
Guru.....saailer
Jun 18, 2010 | 2003 Chevrolet Silverado 1500
ViewSonic N3250W Television with FSP212-3F01.dead needs VOODOO
I am working on the same power supply right now, my has a bunch of bad caps that I already replaced but I did not try to turn it on yet becuase I see that RS1 and RS8 are missing, some one had try to fix this power supply. Can you please tell me the value of these two resistors? Please see my pictures at http://s807.photobucket.com/home/budm/allalbums
Your problem sound like the logic board problem, I can tell you what you should have if I can find out if these two resistors were left out from the factory or some had removed them. I fixed the same power supply for the N2652 but I did not take the pictures of the board, I wish I did.3a99fcd.jpg
Jun 17, 2010 | ViewSonic N3251w 32 in. LCD HDTV
I have a ViewSonic N3250W Television with FSP212-3F01 power supply. The power supply looks OK no visible caps problems no burn signs. I get the 5 Volts output OK but not the 12 Volts or 24 volts. The red...
Does the LED kick on when you push the power button or when you apply power? Typically, the 5volts will run the microprocessor and that looks for a command (power button). When it sees a command, it will send a signal to the power supply to kick that on.. so at this point, you want to look for that signal. If you push power and no power on (p_on) signal goes to the supply, its likely your main board.. but if it does, and the supply doesn't react, then maybe its the power supply. I am not totally familiar with this tv, but thats how all of them really work. Even if the caps look good, some could be bad.. look for brands like "capXon, sanXon" are typically the defective ones, theres another but its slipping my mind.. usually 1000uf @ 16v are bad, or 2200uf @ 10v are also common.. you can search the value and the little code, usually like C9M or something and see if that batch has known issues..
let me know what you find, or how I can help
Jun 15, 2010 | Televison & Video
Power to Motherboard but will not bootup?
most likely a failed hard drive as all of the boot requirements are on it
Apr 24, 2017 | MSI 694T PRO (6309-470) Motherboard
Do you have a diagram that would show me step by step how to install the new power suply I bought for my computer.
Their is really no diagram to show you how to hook up your supply.
You only have a hand full of plugin connections.
Your 24 pin connection to the mother board, you may or may not have a 4 pin 12 volt video connector, which has to be connected if on the board., and your fan connections.
Everything else is controled thru the motherboard.
Nov 25, 2009 | MGE 400W Power Supply (QG) Power Supply
Timer not working Malibu ML88T Power pack
there are multipul 12 timers on the market BUT if you use a 12 volt power pack designed for a car radio display or even a simple 12v 5 amp laptop power suply and a cheep outdoor timer or cheeper indoor timer and run wires inside you can add lights
remember theise lights are low voltage and if you change the bulbs out you can really strech out the amprage too
low amp led automotive bulbs are a great invention they draw mili amps and use 12 volts
i converted my noma moonrays to a laptop power supply and added 30 more to a single string so i curently have 50 lights on 1 power suply pulling aprox 4.5 amps out of a 5A power supply i used led bulbs and simple moma cord now i can light the whole back yard with 1 ps and it's really bright if i use the led headlamps mounted under the soffit on the house
Aug 04, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
