Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
No sound on westinghouse vk-42F240S? - Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
3 Suggested Answers
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Posted on Apr 29, 2009
westytech
  • 120 Answers
SOURCE: I have a westinghouse 42
Normally it depends on what connection you are using to output a signal, all of the inputs on this unit are in one single board. What you need to do is to replace the main board because it sounds like your inputs migh have gone out. To check price and availability on the main board you can contact Westinghouse parts department at parts@wde.com, please make sure to include the model # along with serial # and TW# all loacted on the back of the unit. Hope this information was helpfull.
Posted on Jan 22, 2010
How do I reset my tv or set it up
Westinghouse 40 Lcd Manual - Heroku
gfdc.herokuapp.com/Westinghouse-40-Lcd-Manual.doc
Westinghouse 40 Lcd Manual - gfdc.herokuapp.com ... led 1080p hdtv - westinghouse 40 class 39 5 diag led 1080p hdtv black model dwm40f1y1 c ... lcd hdtv - buy westinghouse uw40t3pw 40 1080p 120hz lcd hdtv led lcd tvs amazon ... 1080p hdtv dvd combo user s manual vk 40f580d tv dvd combo pdf manual download, ...
Sep 17, 2016 | Westinghouse 40" Class LED 1080p HDTV...
I have a ModelVK-42F240S that has no audio. Anything to try to cure the problem? Westinghouse TV
Hi, bad speakers in many flat panel TVs is a common problem. There will be av out sockets at the back of your tv. Please connect the audio from here to any amplifier or any music system you have. If you get the tv programme sound, most probably the speakers are bad. In case you do not get sound, your tv is not producing it. If the speakers are bad and you can change yourself, give it a try. Otherwise show the set to someone qualified to repair it.
Feb 23, 2015 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My audio is out on my Westinghouse Tv VK-42F240S. How do I fix it?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Spare parts are available at most of the electronic spare part selling shops.
Nov 10, 2014 | Westinghouse Televison & Video
TV has video but no sound
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Sep 11, 2014 | Westinghouse 55.70E01.021G Main Board for...
I have a westinghouse 42" VK-42F240S tv. No input signal. I have reset factory setting, changed cables, and boxes. Any suggestions?
Jan 21, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
I can't access the DVD features on my Westinghouse vk-40f580d, I put the dvd in and go to the DVD menu, but wont let me use any dvd controlls, it wont on the remote and tv buttons, AND I cant eject, please...
to eject the disc, turn off your TV and hold the eject button then power TV back on. Regarding the DVD feature not working, you may need to change the main board. If your TV is still in warranty, call 1-800-701-0680 for an in home service.
Jul 01, 2009 | Westinghouse Electric VK-40H580D 40 in....
Apr 08, 2009 | Westinghouse Televison & Video
Moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
Oct 18, 2008 | Televison & Video
Remote control code for westinghouse sk-19h210s television
I just tried a Sony code for my Westinghouse tv after reading other sites, and it worked. The code that worked for me was 10000
Oct 21, 2007 | Televison & Video
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
61 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
