Question about r8 relay relay location/code no.: . fuse box/relay plate
Relay location ac compressor audy r8 2013 - r8 relay relay location/code no.: . fuse box/relay plate
4 Suggested Answers
  • 1129 Answers
SOURCE: Where is the AC Clutch Relay located on a Audi A4
Go to ebay motors and buy a repair manual on cd ($15.00) this will have a handy electric component locator in the software that wiill show a schematic illustrations of relays locations.
Posted on Jul 14, 2009
  • 114 Answers
SOURCE: audi tt ac won't work new compressor, drier and
Did you replace the high and low pressure a/c switches?
Posted on Sep 19, 2009
  • 6468 Answers
SOURCE: audi a4 ac compressor always broken
do you have power and ground to the clutch?
Posted on Aug 28, 2012
Where is the ac relay located on a 1994 ram van 3500?
It maybe a low gas pressure fault as low pressure will not allow compressor to drive.
May 26, 2014 | 1994 Dodge B Series Cargo
Ac relay not energizing on 2005 ford freestar
The very 1st thing you do is see if the AC system has lost its charge of refrigerant. If the system is low on charge then the relay will not engage because it receives no signal from Compressor cycling switch which in most Fords is located in the low side AC line from the compressor, the low pressure line is the larger of the 2 lines from the AC compressor..
Mar 23, 2012 | Ford Freestar Cars & Trucks
My ac does not have power to clutch. I changed compressor and the ac switch where is the relay switch on 1987 nissan pick up
The A/C Compressor relay is located on the firewall, there should be a couple of relays in this location. I have added a diagram which should assist you in locating this relay.
Hope this helps...
Sep 20, 2011 | 1987 Nissan Pickup
WHER IS AC RELAY ON 98 CADILLAC DEVILLE
A/C Compressor Relay In engine compartment fuse/relay center.--------- There is also a fuse.Check the AC fuse 10amp in fuse/relay center.------- Both located under hood, in the engine compartment.-------- For the diagram of fuse and relay, click the link below:--- http://technoanswers.blogspot.com/2011/07/ac-compressor-relay-and-fuse-diagram.html --------- This should help.Thanks.Helpmech. .
Jul 12, 2011 | 1998 Cadillac DeVille
My husbands 93 park ave ac compressor is not running, when he relplaced the ac relay it worked one time and then no longer works. There doesn't seem to be any power getting to the compressor, could there...
If it has the auto air functions.On the passenger side under glovebox remove the black cover under the dash and there is a hidden fuse block with a ac fuse. Check for this a very common issue. Also if the ac is fully charged you can unplug the low pressure switch located on the accumulator( silver canister located by the relays towards the firewall) and take a wire and place between the two terminals just make sure the compressor will does come on.If the ac is turned on and you jump that switch and the compressor does turn and ac starts working then a good possibilty that the low pressure may be bad. Would check the fuse first.
Aug 12, 2010 | 1993 Buick Park Avenue
Audi A4 Ac charge valve.
On that year a4 and a6 there is no low side charging port. (sucks)
The way you charge those systems is by evacuating all of the refrigerant, then with the vehicle off, add the correct amount of refrigerant to the high side port (turning the compressor over by hand occasionally)
Sep 11, 2009 | 1996 Audi A4
Where is the AC Clutch Relay located on a Audi A4 2001 1.8T
Should be in the relay and fuse block under the hood next to the fender. The diagram should be under the lid after you take it off of the fuse block
Jul 14, 2009 | 2001 Audi A4
Fuse diagram for the 2001 jeep cherokee sport 4.0L needed
Believe the AC compressor Relay is located on the left side of the Fuse block inside the passenger kick panel. Exact location is in your owners manual.
Fuel pump relay is inside of the Engine Fuse block under the hood on the passenger side. Locations are written inside of the lid.
May 30, 2009 | 2001 Jeep Cherokee
Ac compressor relay location
should be in the fuse box under the hood
Jun 18, 2008 | 1991 Pontiac Bonneville
r8 relay relay location/code no.: . fuse box/relay plate Logo
29 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Phil Fisher
Level 1 Expert
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
