Question about LG LP1200DXR Portable Air Conditioner
Cycles on and off, about 5 minutes cool 10 warm
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: dyer malfunctions
Clean off the two metal bar inside the drum, near the lint filter. (these are the moisture sensors, which can become coated with fabric softener sheet residue, preventing the dryer from "seeing" that the clothes are still wet)
Posted on Jan 13, 2009
How do you flush?
The cooling system?
Loosen the bottom rubber radiator hose and let the coolant run out.
Buy a can of coolant system flush. Reconnect the bottom radiator hose, pour the can of coolant flush in and top up with plain water. Drive the car for about 10 minutes until the engine is warm.
Then remove the bottom radiator hose and let the water run out.
Reconnect the bottom hose and fill the cooling system with coolant/water mix. Run the engine for 5 minutes and then check the coolant level
Jan 15, 2016 | Cars & Trucks
Compressor on freezer running but not cooling
Dependingmon the length of run time will determine the problem. If the compresser cycles on and off within a couple of minutes then you are looking at a bad compresser. If it runs for 5-10 minutes then cycles off, you have a plugged off condenser or dead condenser fan motor, in which case do not run the fridge until the motor is replaced and cleaned. If the compresser runs for hour or so with no cooling effect then you may have a plugged off cap tube which means a repair man will need to take care of that. If the compresser cycles every 10-30min with a little cooling in the freezer then you are looking at a bad thermostat. Hope this helps
Sep 09, 2012 | Frigidaire Refrigerators
5 yr old tv goes through cycle and tries to come on, eventually does but after many tries.
My sony did almost the exact same thing. I removed the bulb & cleaned all the dust out of the cooling ducts & the screen on the bulb was full of dust. That bought me about a month, then I replaced the bulb & haven't had a problem since(over a year ago). Just make sure you NEVER touch the glass of the new bulb with your hands,oil on your skin will greatly shorten the bulb life! I found a bulb at a local electronics store for under $200.00... don"t forget to clean dust from cooling ducts,& make sure cooling fan is working, bulb gets extremely hot!
Mar 02, 2012 | Televison & Video
My Samsung RB1855SW refridgerator not cooling
You may just be catching the unit during normal defrost cycles. Next time, allow the unit some time to complete it's needed task. If you allow it 30-minutes, it should restart on it's own. The cycles are necessary to keep the unit working properly. The cycles will be more frequent as the weather warms. If you allow the unit 30-minutes and it does not restart on it's own, then there could be a problem. You might consult the owners manual for more details.
Apr 06, 2010 | Samsung Refrigerators
Car wont work after the initial warm up die down situation
Crank sensor or module. Check fuel pressure too.
Jul 03, 2009 | 1999 Pontiac Grand Am GT
Fridge cools for awhile then compressor cycles on and off
Not the compressor. Two reasons why. If your compressor was bad, you would not hear it at all, also the compressor would be very hot, do to the piston not moving and the shaft just moving or the liquid not turning into vapor. One way to check for sure is to take a multimeter and see your voltage. You can also touch the suction and the liquid line, if one is cold and the other is hot or warm then compressor is working ok. Also when you unplug the system and you reset everything, you are not reseting the compressor you are reset the relay
Feb 09, 2009 | Refrigerators
Dyer malfunctions
Jan 13, 2009 | LG WM-2277HW Front Load Washer
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
LG LP1200DXR Portable Air Conditioner Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
