Question about Toshiba 37AV500U 37 in. LCD TV
How do i reset a toshiba 37AV500U tv - Toshiba 37AV500U 37 in. LCD TV
My 37av500u TV wont turn on the green light comes and stays on but the screen stays black
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary..
Nov 05, 2016 | Toshiba 37AV500U 37 in. LCD TV
Television reset
Just unplug it from AC mains wall socket, and re-plug it back after 20 minutes or so. This procedure should make it right. Electro help
Jul 17, 2014 | Toshiba 37AV500U 37 in. LCD TV
I am having trouble removing the subtitle feature from my Toshiba AV500Utv. I followed the owners manual and it if not help. If any advice could be offer concerning how to disable the subtitle setting or...
Looking for the CC button on the remote to close Close Captioning.Finding the button CC on the remote press it couple times for CC1,2,3 to all off,should have no more Close Captioning.Tries tv unplug,replug it back like 24 hrs later for to earase all the save data for the tv Tuner signal board.
Feb 05, 2011 | Toshiba 37AV500U 37 in. LCD TV
My green power light on bnottom comes on then goes off
Tries tv unplug,replug it back like about an hour.The tv now it resetting itself back to the factory setting,the tv shuold work again.If not have the same result,mean tv have power supply board problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 20, 2010 | Toshiba 37AV500U 37 in. LCD TV
Toshiba 37av500u turns on but no backlight
FAULTY INVERTER BOARD INSIDE SET REPLACEMNET REQUIRED AVERAGE COST OF REPAIR £60 TO £80+ SHOP AROUND FOR BEST REPAIR DEAL
Aug 25, 2010 | Toshiba 37AV500U 37 in. LCD TV
No color depth on toshibay 37av500u
Ur Tuner Signal board is dead.That the board should be replaced.
Jan 26, 2010 | Toshiba 37AV500U 37 in. LCD TV
Changing channels is very slow; is there any way to correct this?
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
DON'T FORGET TO RATE;
Aug 10, 2008 | Toshiba 37AV500U 37 in. LCD TV
Toshiba 37AV500U 37 in. LCD TV Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
