Question about Simpson Washing Machines
Simpson easyloader when start is pressed my machine gives 3 clicks (like the door locking) and that is all it does...
SOURCE: Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Posted on Nov 18, 2008
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: door locked indicator light flashing
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Simpson Front Loader won't start - Clicking Noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 15, 2010
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
How do I reset my simpsons eze loader 5.5fkg front load washer 45S558E.. have installed a new LOCK DOOR part
turn off the mains hold power on
turn on the mains plug
have you tried holding in buttons and turning on the mains
wait a min??
perhaps it wont lock the door because of a connection fault
the controller is detecting your closing the door
next in the routine is usually start to detect motor and add water
perhaps the intake valve has failed and the machine isnt detecting water...?
Dec 09, 2014 | Washing Machines
Wfw9150 door won't unlock
Try pressing the "end of cycle" button on the right side of the panel for 3 to five seconds. Wait for 3 minutes to open the door, do not force it. And you start all over again. Please reply as to the outcome. And if it is good you give me a 4 thumbs up rating.
Mar 14, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Our easyloader 7 wont work all the light are on but when we press start it wont turn on we have plugged it out switched it on an doff and cleaned all the filters
Could be the door isnt closing properly, or a problem with the door lock itself. Also check that the taps are turned on.
Jul 31, 2011 | Washing Machines
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
Simpson ezi loader 5.5kg front loader. when it goes to start the door clicks 3 times then the end light flashes. I am an electrician. but I do not work on appliances. if you could send me a...
the door is clicking because it is trying to lock the door but is unable to for some reason what is the make/ model number of the machine? most likely it would be something dealing with the door look but id rather be 100 percent correct then assuming Please send model number i await your reply Thanks again
Rick
Dec 09, 2010 | Washing Machines
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Nov 08, 2010 | Siemens Washing Machines
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
Good luck.
Apr 27, 2010 | Zanussi FS1455W Front Load Washer
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Jan 14, 2009 | Washing Machines
Washing Machines Logo
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
