Question about Microwave Ovens
I have a small hole in the back wall of microwave model#em720cpi is it still safe to use
Falling Down
  • 67 Answers
SOURCE: Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Posted on Nov 30, 2007
  • 5 Answers
SOURCE: Panasonic Slimline Stainless Steel Combination Microwave
First of all, is the hole a factory one that you never noticed before? If so, leave it alone. I know that microwaves generate a lot interior heat and it needs to escape someway. Secondly, if it is not a factory made vent hole and you can't be sure if it caused from a lot of use, and if the oven still works fine, I would not worry about it if it were me.
Posted on Apr 17, 2009
najah
  • 180 Answers
SOURCE: I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
Posted on May 30, 2009
SOURCE: Metal plate on inside of microwave has hole & is arcing.
The Arcing is a real bad sign, and you see the "Brain" has detected a fault condition, most likely the Power Supply and or magnetron, or High Power Diode, has "Faulted" and it shuts down for Safety reasons. Due to the danger existing inside MW, I recommend that you have it serviced by a qualified person. Always get a firm "Quote" before proceeding with any work. Be careful, as often a repair may cost as much as a new one.
Posted on Mar 13, 2010
Testimonial: "Thanks for the insight. We will definitely look into the items listed and have it looked at by a qualified repair tech."
pgh_pa_guy
  • 2992 Answers
SOURCE: magnetron has 2 small holes in antenna due to
Some magnetrons have holes in the antenna by design. If these are clean holes on opposite sides near the RF gasket then they belong there. If the holes are obviously burn damage but don't cause any improper operation, the oven is safe to use.
Posted on Apr 10, 2010
Hole burned inside microwave... is this safe to use?
Just get a tube of 2 part epoxy and fill it. Could be a hazard otherwise.
Dec 20, 2017 | Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Magnetron has 2 small holes in antenna due to previous wave guide being dirty.Is the microwave still safe to use,no sparks or arcing.
Apr 10, 2010 | Sharp R-820B Convection/Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
May 29, 2009 | Microwave Ovens
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Jan 08, 2009 | Microwave Ovens
Nov 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Pin hole in back wall from metal carousel hitting wall while oven on
You can buy stainless steel tape from many hardware stores, just make sure that you put the tape on the outside (be very careful when opening the oven up). Put enough layers on to match the thickness of the metal originally - unfortunately the tape tends not to stay on for that long, so is potentially a dangerous option the best thing to do would be take it to a microwave repair shop - they will have metal sheet available of the appropriate type and should be able to patch it for you - if you get really lucky they might have the same model that has an undamaged chassis but destroyed electrical workings - is worth a try. Good luck Hope this helps - please post again if you need more info :)
Apr 18, 2007 | Dacor DCM24SS Convection Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
