Question about Refrigerators
Water driping from freezer to ref.I khow its pluged
Water driping from freezer to ref.I know its pluged with ice but what is quick fix without turing it off
    President:
  • 744 Answers
The easy way to fix is unplug appliance - take back panel off freezer - melt ice in pan below evaporator - when ice is melted and you see drain tube mop water up with paper towel - with a measuring jug pour hot water into pan/tray below evaporator...repeat this at intervals of a few minutes 2-3 times moping water up each time with paper towel - next find something flexible to clear blockage in drain tube, curtain wire works - when you see water suddenly drain down tube blokage has cleared.
put back together and plug in..you are good to go.
Hope this helped, if you need any further assistance of have questions please feel free to comment again.
Posted on Jun 23, 2009
My Kemore fridge is driping water in side under the top shelf!
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Kenmore Refrigerators
Driping of water from top inside of refrigrator compartment. leaving every thing filled with water in refrigrator.
Leo Ponder
imufo2
Sep 17, 2011 | Haier HRF10WNB Top Freezer Refrigerator
Water keeps driping from where it comes out to fill up ice trays
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 12, 2011 | GE GSS20IEP Side by Side Refrigerator
I have a kenmore elite trio fridge with bottom freezer. recently, the ice maker stopped producing ice yet the water is still being dispensed from the refrigerater. wondering if there might be a quick fix...
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Aug 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
It appears the icemaker water is leaking down the back of the freezer and pooling/freezing at the bottom of the freezer side. Ice continually forms around the fan on the freezer side. Is there any quick...
NOTE: This
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | Frigidaire Refrigerators
Water driping from top inside ref
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 22, 2011 | Refrigerators
Water driping from freezer to refrigerator
If this is a side by side refrigerator, water dripping from the cold air return indicates a warm air leak, or some source of constant heat presence. Check to make sure doors close completely, that you have a tight seal along the entire edge of all four sides of both doors, that a light is not staying on when door is closed, that your ice maker is not stuck in the harvest cycle which turns a heater on underneath the ice maker, some other cause not determined without personal inspection.
Jun 28, 2010 | Whirlpool GD2SHGX Refrigerator
Water leaking inside
Hi,Open the freezer compartment, unsrew the two nuts. pour a little warm water to defrost the bult up ice on the freezer compartment. At the estreem end, a shining drain pan might full of iced remove the ice at the center of the pan you will see a hole blocked with ice, pour hot water on it till all melted away. open the back of your refrigeration there is a water drain hole, around the left hand corner. see if the hot water driping off. this resolve the problem.
Thanks and Good luck
Jun 04, 2010 | Maytag MTB2176 Top Freezer Refrigerator
Water driping on top shelfe from freezer,
The drain most likely was blocked by food debris and the water from defrost cycle had no where to go...unplug refridge...chip some of the ice along the bottom carefully or use heat gun to melt ice...when the tube becomes exposed put some hot water in the drip pan..this should help the ice melt in the drain tube....use a straw or curtain wire to clear blockage...you should see the water suddenly drain down tube...put everything back together...this is not a temp issue but more a blockage issue.
Jun 23, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water in the refrigerator portion...
the drain in the freezer is blocked with ice,unclog the drain by letting the whole thing defrost or take the back cover off inside the freezer and locate the drain hole and pour hot water over the drain and sponge up excess and repeat if it does it again after you unblock drain you need a defrost timer
Jun 13, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
