Question about Games
Soldiers in training elected these - Games
What Year Were Soldiers Sent to Battle in the Second World War?
It depends on the country. Some countries were fighting in 1933, while others didn't come in until later.
Jan 04, 2017 | Homework
Why dose my RCA projector tv shut its self off and on then off.
It sounds like you need the RCA HDTV Convergence repair kit. On these TV's they used no lead soldier. After awhile the soldier on the Flyback would cracked causing one small fuse to blow and sometimes a capacitor to go out . It's hard to see you need a magnifying glass with a light. Look for small circles around where the terminals are soldiered. When I replaced mine I also reheated the flyback soldier and added my own soldier from radio shack. If you can take the back off your TV, remove the board the flyback is on, and use a soldier iron then you can fix it. I just seen a kit on ebay for $10.00 dollars plus $3.00 shipping.
Aug 08, 2014 | RCA Televison & Video
What weapons are used in the Israeli martial art of Krav Maga?
In Krav Maga, trainees learn to use as well as defend from many contemporary weapons found in today's world. In the IDF, when learning Krav Maga, soldiers are trained to use the M-16 as a weapon, as well as defend from it. Other conventional weapons used in Krav Maga include: hand guns, knives, and sticks. In addition, improvised weapons are used as well. Such weapons include broken bottles, ropes, rocks, and soft drink cans.
Sep 06, 2012 | Century Martial Arts
Can not beat the end of level 5 with the groups of people coming towards me and having the machine gun, not sure if there is a better way to beat them any advice would help
Oh, yeah... the f**king train of shield-bearing terra cotta warriors. I spent roughly an hour (combined with a great deal of swearing and smacking my Wii-mote) trying to get past this part before I finally succeeded.
While there is no real "solution" to beating this part, there is a method that I used with a fair amount of success to get past it.
What you need to do is move your machine gun (using the joystick on the nunchuk) so much that you have the middle and left-hand crossbow sniper points in your field of view. This alone will cut the difficulty down considerably, because you'll be able to take out any snipers that appear in those spots without having to pause to move the gun until they are in your field of view. If a sniper pops up on the right-hand wall, wait until you've taken out all the soldiers who have made it past the wall before you take out the sniper on the wall.
When dealing with the shield bearing soldiers themselves, I recommend two tactics:
1) Focus on gunning down the soldiers in a wedge shaped swath, with the "tip" of the wedge beginning in the left-hand column of soldiers.
2) Whenever possible, try to shoot at the soldiers behind the front row of each fresh wave of soldiers. This will weaken them, and cause them to go down faster once you've taken out the soldiers in front of them.
Additionally, when you've got a large amount of space between you and the next approaching wave, spread your shots slowly along the entire row of soldiers, which will let you damage both the front row of soldiers AND the rows behind them.
Also keep in mind that getting through this part also depends on a great deal of sheer luck. Keep at it, and eventually, you'll find your rhythm for cutting down the soldiers before they can get to you, and you'll manage to get past this part.
Feb 23, 2011 | Nintendo The Mummy: Tomb of the Dragon...
Kenmore Washer has Elect smell; no pump, spin, or agitate.
The ECU/Controller has failed. Replacement is your only option.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Washing Machines
The Cable Connector in the back of my TV is loose.
The connector is connected to the tuner with soldier, when this breaks from mechanical stress, you get the symtoms you described. This is an easy fix. You will need a fairly high wattage soldiering gun, and some medium electrical soldier. This will run you around $30 at Radio Hut. You will need a gun that will do ground straps so dont get one that is under 80W. 100-150 watts is good. Actually you should get some good rosin flux too. The chromium or molydenium in those connectors can make them hard to soldier.
Soldier them hot and fast. Lightly clamp the male jack to the tuner. Tightly, you need good thermal flow. brush on your flux. ALWAYS Heat your gun FIRST. Til it gets good and hot. Flux, and tin the tip of the soldiering gun too. put the tip of the gun closest to where the two parts meet so you are heating both parts. When the parts are hot feed the soldier onto the hot parts NOT the soldiering tip!
You must do this VERY quickly. As in 3-7 sec to heat the parts, and push the soldier in as fast as it will melt, then get the gun back. Another note, if your soldiering tip isnt 'wet' with soldier you wont get thermal transfer. Also, if you fail to soldier try once more, but the internals (plastic) of the male jack will melt if you overheat, So cool it down somehow if you fail to get a good soldier, or just walk away for awhile.
These can be troublesome to soldier. Practice with you new gun on something else to get a feel for it. If you want to simulate the problem, take a coax coupler, and try to soldier it to a piece of sheet metal. Hope this helps!
Good Luck!
Mar 15, 2009 | RCA Televison & Video
Games Logo
51 people viewed this question
Top Games Experts
Pamela Leach
Pamela Leach
Camryn Johnson
Camryn Johnson
Level 1 Expert
Are you a Game Expert? Answer questions, earn points and help others
