Question about Magellan RoadMate 5045LM 5" PND w Lifetime traffic maps
Not working after trying to do descale - Magellan RoadMate 5045LM 5" PND w Lifetime traffic maps
What is wrong with my silvia? No coffee or water, but steam ok. Loud burring noise
Hi There,
Your coffee group is blocked, with lime or coffee oils.
Try descaling 1st Pulycaf coffee machine descaler . You will find descaler and cleaner in this rancilio silvia kit. Rancilio Silvia gasket kit . Descaling should be done every 3 months or so.
If the descaler does not work - you may have to remove the solenoid valve and descale that - not an easy fix. Takes 20 min.
May 29, 2014 | Rancilio Silvia Espresso Machine
I have a Gaggia Syncrony Compact machine which I am trying to descale. I have added the descaler to the water in the tank. when you hold down the button (26) more than 5 seconds nothing happens.What is the...
To descale the appliance proceed as follows:
• Mix the descaler with water as specified on
the package and fill the water tank.
• Switch ON the appliance with the ON/OFF
switch (7).
• Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
I noticed you did not mention the switch ON before you pushed button 26. Try that should work.
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I ran the coffe machine out of water while making a cup of coffee and now the coffee machine wont make coffee. It sounds like the system is trying to **** water through, but doesnt.
Not too sure sort of same issue on last machine i descaled it and it worked on this one not so lucky so looking for answers too, if you often descale your machine then it wont be this if you havent descaled it for some time, then this could well be your issue, pending on how knowlagable you are, you can take to bits, put CRC or neat descaler into the tubes, there is a little spring clip type of holder you need to take out before removing small tube, use a serynge and squirt some neat descaler into tube and if possible where it came out of, few time before my main issue was at the front water dispenser part, so if you can undo a tube from the furthest point from this then put in descaler attach tube again, put back to gether leave for a little to get through then turn on and try to get hot water out, if so the coffee side will probably work too, but before you have a cup fully descale the machine and rinse through a few times then try a cup
Jan 08, 2011 | DeLonghi Coffee Makers & Espresso Machines
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
My Saeco Italia is stuck in the descaling mode. I tried to descale it yesterday and now it is stuck in the descaling mode. I have tried resetting as instructed in the manual and unplugged it overnight. It...
I had this problem too. I was beside myself wondering what to do. I took the machine apart but there was nothing wrong. It was stuck in an infinite descale cycle. The 5 green buttons never blinked to say it was done. What finally fixed it was to close the steamer valve to where water was being being restricted from the steamer wand but still a little water was spurting out. It finally quit emitting water and the 5 lights blinked and the infinite descale cycle completed. This model espresso maker was a lemon and been nothing but problems.
jeff
May 18, 2010 | Starbucks Saeco Italia Digital Barista...
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
Magellan RoadMate 5045LM 5" PND w Lifetime traffic maps Logo
27 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
