Question about Husqvarna 23 Hp 48" Deck Yard Tractor
I have a 15HP YTH 1542 riding lawn mower. It has a 20 amp fuse in wiring harness. Fuse continues to blow about 3 or 4 minutes after being replaced. What is causing this.
    Problem Solver:
  • 7 Answers
Check wires for short to ground
Posted on Jun 25, 2009
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
I need the owners manual for Husqvarna YTH1542 riding lawn mower.
hi there
paul46 here
please find website address for yth 1542 owners manual for you to download and save
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2007/HOUS2007_O0702036.pdf
check it out
cheers pauly46
Apr 30, 2011 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor keeps blowing a fuse
Check for a wire that has a bare spot on it rubbing the body of this mower. The vibration the engine makes shakes the wiring so it must have a bare spot somewhere under the seat or towards the engine
May 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet 2008 1042 Series
If the problem occured after the deck work check everywhere you worked on the deck. You are lookining for a pinched wire. What is occuring is with the vibration of the mower running the pinched wire will rub and touch ground causing the fuse to blow and shut off the engine. Even if not concerning the deck that is what you have to look for. It can be time consuming but this is what you have to do. The short if not about the deck try checking the seat area this is a common area of problems with shorts in riding mowers.
Sep 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a Husqvarna Yth 180, the lawn mower shut off when I engage the blades to cut grass. I blows the 20 amp fuse near the wire harness
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
Jul 13, 2009 | Husqvarna Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
559 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
