Garrison Model 052-2549-0 THM 703 changed batteries now Heat cycles on when not called for ??
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
I need manual for Garrison 5200 btu window a/c. Where can I find one? Thanks
You will need the complete model number which looks like the following 123-4567-8. The manual can be viewed\downloaded from http://www.manualslib.com/brand/garrison/air-conditioner.html by selecting the correct model number as described above. If your model is not listed you can call customer support at 800-387-8803.
Hope this is helpful.
Aug 02, 2016 | Heating & Cooling
How do I change the lithium battery in my Garrison Programmable Thermostat Model No. 52-8896-6?
The front faceplate simply pulls off - no tools required. The Garrison uses 3 AA batteries. Once you pull off the faceplate you will see where the batteries go.
Hope this helps!!
Nov 01, 2014 | Heating & Cooling
Why doesn't heater heat up when turned on ?
  • I bought 3 convection heater ( model 052-2026 ) .Two of them stop to heat after 2 years using . The third, stop to heat last december. Canadian Tire ( store where I bougt the product ) told me to contact Garrison Company . Now , I want to get refund. Michel L?ger Quebec, Canada
Mar 04, 2014 | QMark Portable Hydronic Electric Baseboard...
Why does my garrison air conditioner (5200btu) not dehumidify and cool at the same time?
people are giving you answers for a "broken" unit. I have the same Garrison 5200BYU, and it's something I hate about it. You'll notice on the controls, theres a setting for "cool" and one for "Dry". Can't run both at the same time. I've never had an air conditioner that didn't dehumidify the air. After all, for cripes sake, it's why they're not called "aid coolers", they're called "air conditioners"! But I don't think your unit is broken, it's just a strange thing with this Garrison. I don't know if all Garrison are like that, or just this one. But this model is for sure. I wouldn't buy another.
Aug 06, 2013 | Danby Heating & Cooling
Need Noma THM 403 english user manual
1) Copy following link for possible Noma thermostat manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Noma-Garrison
2) Add a comment and describe product in detail.
Jan 24, 2013 | Hardware & Accessories
Garrison heater red light on but no heat
I just fixed mine with the same problem. I first called Garrison and they wanted to send a tech out to fix my $60 heater that was just of warranty..I said no of course. Any how I have a electronic background so troubleshot myself and found a thermo fuse that was bad. It was located inside the heater and not easy to get to but that was the problem. I am guessing that the fuse goes because of blockage at the top of the heater. Any how it's fixed.
Oct 24, 2012 | Heating & Cooling
Garrison air conditioner model 04-5443-4 owners manual
Contact the toll free number on your ac. I too had no luck finding the manual through web searches but called the toll free number and within minutes they emailed me a digital copy of the manual.
May 25, 2012 | Heating & Cooling
Cant open Sandleford Garrison Safe N15115
I have a new N15115,ES20 electronic safe,it will not accept a change of password.when new password entered it only beeps once ???
Jul 18, 2010 | Check Point Network Adapter
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
