Question about Fuji FinePix S2000hd Digital Camera
Lost my lens cover as well
I lost my cover as my daughter decided it would be a good replacement for a frizbee and threw it into drain... any idea where i can get this from?
  • 98 Answers
I have a Fiji finepix s3000......check ebay and better yet contact Fuji.......they have a great customer service online system.
Posted on Jun 23, 2009
Do I need see an eye doctor to get non prescription colored contacts?
If you have a good vision and needn't vision correction, you can buy nonprescription colored contact lenses (0.00 power lenses) directly from optical shops. According to my knowledge, Bright Eyes Contact is the best online store which provides natural colored contact lenses that are really cool contact lenses available in a variety of patterns and diameters, circle lenses can multiple effects, ranging from natural-looking to super bold look.
Sep 06, 2012 | Niles IntelliControl ICS CONTACT Color...
Samsung S85 camera wont turn on. When the power button is pressed the green light flashes and the camera beeps three times than turns off. how do i fix it?
I quote the solution posted for another expert about this same problem...
My daughter has a Samsung S850, and returned from a weekend trip last night. She pressed the "Power" button and the blue light next to the button came on, as did the screen. The camera then gave a "buzzy beep" three times and shut-down. She decided the batteries were low and replaced them with ordinary AAA alkaline batteries, nothing special, and got the same result.
This morning I checked the voltage on the new and old batteries with a volt-ohm meter and found the old ones were low but the new ones were good.
I read this site and saw a comment that the camera worked after the lens was worked a little bit.
Upon a close look at the lens, I could see tiny grains of sand around the outside of the glass, so I got a wooden toothpick and gently worked the sand out with plenty of tapping on a solid surface to drop them from the area. I also worked the tip of a clean toothpick under what appears to be a soft rubber sealing ring on the outer surface of the glass.
After all this, when the "Power" button was pushed, the lens moved out and the screen lighted, and all the camera now seems to be working.
I should add that shortly after my daughter bought the camera, she lost some kind of metal or plastic ring from around the lens, and that left the "works" around the lens open to view: I can see two tiny screws the lens that are probably ordinarily covered.
Is the lens supposed to be covered by a curtain when power is off? From what I see, the lens is always uncovered. Maybe that lost ring held something else!
Its possible that
it needs repaired by samsung; You can follow the below link for tech support - http://www.samsung.com/uk/info/contactus.html
Hope this helps; send us you test comments.
Feb 26, 2011 | Samsung S85 Digital Camera
When power switched on lens cover dose not open comes up on standbye
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the service as you do not have to run around for spares.
Feb 19, 2011 | Samsung Digimax A400 Digital Camera
My freezer is still freezing but the fridge is not cold. You can hear it running but nothing. HELP!
is the fan running in the freezer? if not replace fan .if not unplug fridge,,remove all inside pannels in freezing unit,,in the bac ,in the middle, on the bottom ,there is a drain that drains into the very bottom of fridge,is it like aice bottom across the bottom of the freezer?if so,use hot water to defrost all the ice and may be a hair dryer,water will melt and **** down the drain threw the drain tube,to the bottom of fridge into a shallow pan under the fridge,that slides out(could be messey).clean all bottom of freezer out good(crumbs mostley)that stop up drain and pour water threw drain a few time to clear drain good.reasemble and ur good to go.now if there is no ice and drain is good,you might find ice on coils,this means ur defrost timer is most likeely gone out ,just replace timer
Jul 04, 2009 | Electrolux Refrigerators
Sharp lc46d64u screen has vertical green lines
Unfortunately my friend, there is not a whole lot that can be done. Sharp has a great limited warranty, but it does NOT cover ANY problems due to physical damage. Getting screens replaced often times cost more than the tv itself. Save yourself the trouble of getting pissed off at sharp because they wont help you if you decide to call and replace the tv. Good luck 2 u
Feb 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Lens cover won't open
You should look for "lens cover mechanism" when open camera front cover. This part has defective gears or misaligned some thing internally. Part detail is as under for Sony DCR-DVD653E model.
( 1-787-236-11 ) MOTOR UNIT (LENS BARRIER)
You can have an idea of this part in below exploded view... I hope these info will be useful.
Oct 29, 2008 | Photography
My Samsung S850 Wont Turn On
cameras beep when it has a problem. most likely the lens get stuck or lens gear failed or motor drive gear to lens, or allot of other problems like it doesnt reconize the optical sensor.
look online for the beep codes and problems.
ty
hope I helped
Jan 27, 2008 | Samsung S850 Digital Camera
Fuji FinePix S2000hd Digital Camera Logo
123 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
