Question about Delfield F2987C
What does code E 13 mean - Delfield F2987C
What does code 13 mean for a 2000 mercury cougar
If you mean P0113 then it is an intake air temperature circuit high output. Which means some of the possible problems could be a dirty air filter, defective intake air temp. sensor, defective MAF sensor, or faulty or corroded air intake temp sensor.
Now if it code
P0133 then the cause would be an O2 sensor. Which is bank 1 sensor 1.
In some cases on older vehicles code 13 means there are no problems but that was back in 95 and before.
Dec 27, 2015 | Mercury Cars & Trucks
Air bag flashing code 13
Code 13 means the airbag circuit is shorted or grounded. Hope this helps!
Feb 25, 2015 | 2009 Nissan Versa
I have the code but the screen says looked 13 and canot enter code
locked 13 means 13 incorrect code tries have been used - the unit will need to be reset with special equipment. If its a car DVD player there is a way around this but not if its a radio/cd
Dec 17, 2013 | Car Audio & Video
My Honda says a 13 what does that mean
If you mean engine trouble code 13 and the Honda is older than 1996, it means the barometer or map sensor has a problem.
Sep 02, 2013 | Honda Civic Cars & Trucks
I did a diagnostic check and it came out with codes 12 13 and 54. What do I need to do to get my truck back up and running?
code 12 means the battery was disconnected within the last 50 key cycles. ignore this code. code 13 means no change in map reading and the baro reading at start up. check for vacuum line break or loose connection. If vacuum lines are ok, replace the map sensor if the codes still exists after the code 54. Code 54 is no fuel sync to the pcm. Replace the camshaft sensor under the cap, then when the vehicle is running, check and see if code 13 is still there (erase the codes first).
Jan 11, 2011 | 1995 Jeep Grand Cherokee
I'm getting an "E 13" code on my Monitor 2400; what does that mean? I don't have a manual to tell me.
E 13 means ignition failure. You can see a list of error codes at www.monitorproducts.com. What happens when you try to light the heater? You can contact me at nitensheaterservice@embarqmail.com.
Jan 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My service light came on saying a 13
13 is really dangerous. you shouldnt drive the car. call a mechnic should come out to look at it. 13 means that the engine is in the last stages of its life. be careful, it may blow up in ur next ignition start
Jul 03, 2009 | 2004 Acura TL
Error code 0 13
1:Error Code 0 13 could be telling you that your "Air Filter" needs Cleaned.
2: If that does not work Call "Sharp" at 1-800-237-4277, follow the Prompts for "Air Conditioners".
3: When you reach a person give them Reference # 5263448. that is for your current problem, I have already spoke to them about.
Hope I Helped
George
Apr 28, 2009 | Sharp Heating & Cooling
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
Mar 14, 2009 | Sony Televison & Video
Refrigerators Logo
18 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
