Question about Aqua Vac Tiger Shark
My Tiger shark was repaired with a new motor last fall. This is the first time it has been used since then. When putting in the water it is running but fails to go forward or backward! What can I do?
    Champion:
    Scholar:
  • Aqua Expert
  • 239 Answers
It sounds like there may be a problem with the drive gear mechanism or drive belt
Posted on Oct 05, 2014
5 Suggested Answers
  • 106 Answers
SOURCE: How can I keep my Tiger Shark from sticking to the main drains.
Decrease suction on main drain and increase suction to cleaner.
Posted on Jan 15, 2010
thepatioman
  • 52 Answers
SOURCE: My tiger shark pool cleaner spends a lot of time
the tiger shark is designed to climb but you can adjust the weights to keep it down. check out http://www.aquavacsystems.com/Weights-and-Floats_ep_31-1.html
for more info and specs of your unit. good luck
The Pool Tech
Posted on Jul 14, 2010
jharwell668
  • 640 Answers
SOURCE: my tiger shark pool cleaner
The pool cleaners impeller may be clogged or jammed with debris. Check and clean if necessary. The brush rollers or drive tracks could also be stuck. Check for debris and remove. It is most likely one of these problems if it is shutting off after only seconds of running. If these don't seem to be the problem, I would check your power source.
Posted on May 11, 2011
john224
  • 1378 Answers
SOURCE: My tiger shark does not
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Posted on Jul 25, 2011
Acqua water shark won't move
This action is a typical response to a drive motor unit with water intrusion. While the motor is probably not completely water-filled, the amount in there gets circulated when the motor first starts and the internal motor circuitry detect the water and shuts down the drive motor as a safety feature.
I was able to take apart my drive motor on another brand, dry it out, and reseal the casing using silicone rubber.
Drive motors are expensive, but generally, still a good value compared to buying a new unit. If you can repair or replace the motor yourself, it becomes economically feasible.
If you do repair the unit, always be vigilant and remove the unit as soon as it has done its job. Water pressure is always trying to push water into the sealed motor units, and over time, it WILL get in...so let your robot dry out between uses.
Jul 02, 2014 | Aqua Vac Tiger Shark
Why does my tiger shark motor run and peller spins but wheels do not turn
if the wheels are not turning, there is a good chance the drive belt is damaged. this can be repaired
Jun 14, 2014 | Aqua Vac Tiger Shark
Tiger Shark moves slow
no tension need to replace tracks
Jun 25, 2012 | Aqua Vac Tiger Shark
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
John
Jul 23, 2011 | Aqua Vac Tiger Shark
I have a tiger shark one and half years old. it turns on, can hear the motor going and it will move and clean regularily anywhere from 20 sec to 5 minutes. but then will get stuck in one spot. the motor...
The motor pack is having trouble and will need to be replaced (most likely). For help finding a service center that can perform the inspection and repairs check Hayward's site at http://www.haywardnet.com/locator/ and fill in the information requested. Be sure to select product repair or service and robotic cleaners to limit the response to those able to fix these cleaners. We are in S.E. Michigan and are one of the centers for Tiger Shark cleaners.
John
Oct 10, 2010 | Aqua Vac Tiger Shark
Aquavac Tiger shark won't operate
The power supply powers on even when it doesn't output any voltage, so it's kind of misleading. You should have the power supply checked or you can do it yourself if you have a multi-meter, by measuring the output and making sure there is 24V.
Jul 17, 2010 | AquaVac Tigershark Plus Robotic Automatic...
My tiger shark pool cleaner spends a lot of time at the top of the water line. How can I adjust it so it does not climb so far?
The Pool Tech
Jul 02, 2010 | Aqua Vac Tiger Shark
Plugged in and turned on but doesn't move
look at the rubber belt wrapping the wheels, there are some little rubber numbs along the belt in order to grap the wheels and make them move. If some of the numbs are broken, the grab is too week to move the wheels. I guess, replace the belt is the only solution
Aug 11, 2009 | Aqua Vac Tiger Shark
Aqua Vac Tiger Shark Logo
266 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Ben Clacy
Ben Clacy
Level 1 Expert
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
