The C 3502 error code in Konica Minolta c 6100, 1100, 1085, and 6085 machines is related to the fusing unit. The error code indicates that the fusing unit is not heating up correctly. There are several reasons why this error code might appear, including a malfunctioning thermistor, a broken fuser heater lamp, or a damaged fuser thermostat .
Turn off the machine and unplug it from the power source.
Remove the fusing unit from the machine.
Check the thermistor and fuser heater lamp for any damage.
Replace the damaged parts if necessary.
Reinstall the fusing unit and turn on the machine.
If the error code persists, it is recommended to contact a Konica Minolta service representative for further assistance
clean rollers or order new ones for 50 cents, just google search for the rollers, also check to see what weight paper you are using, it may work with other or check paper size setting in printer setup. photo paper can be a problem re pick up with some printers
ERROR CODE 3502: is Paper Tray Empty
CODE 3829: Is not listed on the Advent web site. It may be printing head jammed.
https://adventprintersupport-en.custhelp.com/app/answers
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
For all in one printer 3502 error code indicates that main paper tray is
empty or the printer did not detect the paper., Make sure that the
paper is properly inserted and paper tray is properly aligned. You can
also try to clean the rollers of the printer on the fornt and at the
back (Just remove first to rear access door of the printer for you to
able to see the rollers at the back of the printer)
if you are using the 5000 series Printer press and hold copy and cancel to do the media sensor calibration
If this issue not solve call kodak toll free 1 800 421 6699 and send the printer for repair
For all in one printer 3502 error code indicates that main paper tray is empty or the printer did not detect the paper., Make sure that the paper is properly inserted and paper tray is properly aligned. You can also try to clean the rollers of the printer on the fornt and at the back (Just remove first to rear access door of the printer for you to able to see the rollers at the back of the printer)
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
