Question about HP Laser Jet Pro CP1525N
Cp1525nw How do you do a password reset?Password reset
Forget my password how to reset
What password you forgot, Windows password, Windows 8 or Windows 7 password?
How to reset Windows 8 password:
http://www.isunshare.com/windows-8-password/how-to-reset-windows-8-password-without-disk.html
How to reset forgotten Windows 7 password:
http://www.isunshare.com/windows-7-password/forgot-windows-7-password-no-reset-disk.html
Mar 11, 2013 | Acer Aspire 4720 Notebook
Tip
How to Create a Password Reset Disk in Windows 7/Vista/XP?
Forgetting Windows password occurs more often than the users would like to think. So if you haven't created a password reset disk for your user accounts, it's time for you to take action. A password reset disk enables you to reset Windows password if your Windows password is forgotten. If you have no idea, just look at the following instructions.
Windows 7/Vista Password Reset Disk
If you are Windows 7/Vista user, you can create a password reset disk to reset Windows password as follows. Just 6 steps:
1. Enter Create a password reset disk in the Start search box.
2. Press Enter to pop up the Forgotten Password Wizard.
3. Insert a USB flash drive and click Next on the Forgotten Password Wizard.
4. Select the right device store the password information of the use account which you are logged on.
5. Enter the current user account password.
6. Wait while wizard creates the password reset disk. Click Next when it 100% finishes and click Finish to exit.
Windows XP Password Reset Disk
If you still use Windows XP, just take the following steps for reference to create a password reset disk to in case of the need of Windows password recovery. Just 4 steps:
1. Click Start > Control Panel > User Accounts.
2. Select the target user account and click Prevent a forgotten password on the left pane. The Forgotten Password Wizard will appear.
4. Follow the wizard to create a password reset disk.
Windows Password Reset Disk Tips
1. The created password reset disk should be kept in a safe place as anyone can use it to reset Windows password without any limitations.
2. When you enter a wrong Windows password, the Password Reset link will appear under the password box. You can simply click the link to start Windows password recovery with your created password reset disk.
3. If you forgot Windows password without such a disk, you can reset Windows password by a Windows password recovery tool like Windows Login Recovery.
on Jan 06, 2011 | Computers & Internet
Tip
Reset Windows 7 Password With Own Created Reset Disk
How to Reset Windows 7 Password
It is easy for you to create a password on Windows 7 to protect computer data. At often as you might forget Windows 7 password, which may result in serious data loss. In reality, forgetting Windows 7 password is not a big problem as long as you create a Windows 7 password reset disk in advance. A Windows 7 password reset disk can help you easily reset Windows 7 password when you are locked out of computer.
Part one: Create Windows 7 password reset disk
Before creating the password reset disk, please insert a USB flash drive or floppy disk in your computer.
1.Click Start button to select Control Panel.
2.Click on User Accounts and Family Safety, and then click on User Accounts.
3.Click on Create a password reset disk on the left of the following screen.
4.Click Next when the forgotten password wizard welcome screen appears.
5.Select your target device to create the Windows 7 password reset disk.
6.Type current user account password.
7.Click Ok when the password reset disk is created.
8.Click Finish when the completing screen comes up.
When the Windows 7 password reset disk is created, a file named userkey.psw will appear on your USB flash drive. Please remember to place the USB flash drive or the file in a safe place. Anyone can use it to reset your Windows password with it if he can get physical access to it.
Part two: Reset Windows 7 password with password reset disk
When you forgot Windows 7 password and locked out of computer, you can take out of the password reset disk to reset Windows password. Plug your password reset disk in computer, and then follow the below steps for Windows 7 password reset.
1. Log on your computer with the target Windows account.
2. Enter a wrong password in the welcome screen password box, and hit Enter.
3. Click OK when the message that the user name or password is incorrect comes up.
4. Click on Reset password on the following screen.
5. Click Next when password reset wizard welcome screen appears.
6. Select the target password reset disk and enter Next.
7. Enter and confirm your new Windows password and click Next.
8. Click Finish to close the wizard.
9. Log on Windows 7 with the newly reset password.
If you forgot to create Windows 7 password reset disk before locked out of computer
A windows 7 password reset disk can really save you a lot of trouble when you forgot Windows 7 password and locked out of computer. So don't forget a password reset disk before locked out of computer. If you forget to create Windows 7 password reset disk, you can use Windows Password Breaker Professional to help you reset lost Windows 7 password. This safe and reliable Windows password recovery software allows you to burn a bootable CD/DVD or USB flash drive to rest lost passwords for Windows 7/Vista/XP/NT and Windows Server 2008/2005/2000. You can log on your computer again within 5 minutes with this tool.
on Oct 29, 2010 | Computers & Internet
I NEED TO RESET MY PASSWORD (I FORGOT THE OLD ONE)FOR HEWLETT-PACKARD G56-129WM LAPTOP PC, ANY HELP IS APPRECIATED..8)
I reset Windows password with the following easy ways.
Way 1: Reset Windows Unknown Password with another Administrator Account
Administrator account is the easiest way to reset Windows forgotten password if you have it.
For Windows 7, press Ctrl + Alt + Del and click Switch User to change Windows login account. Type another available admin account and password, press Enter to login Windows 7 successfully.
Start - Control Panel - User Accounts and Family Safety - User Accounts, find the accounts you lost password, and click Change your password. Type the new password, confirm new password, and type new password hint for reminder when you forgot the account's password again.
Way 2: Reset Windows Forgotten Password with Password Reset Disk
When you input incorrect password in the password inbox, and press Enter, there is a message "Reset Password" under the inbox on the Windows logon screen.
Just click the "Reset Password" link to continue password reset process. Follows Password Reset Wizard.
Click Next, insert the Password Reset Disk, and select right removable disk. Click Next to go on password reset process.
Way 3: Reset Windows 8/7/Vista Password with Windows Password Genius
You may usually hear Windows password can be reset with 3rd party software. Some are free, such as Ophcrack, but there are a lot of limitations on password reset. Some will cost you, but they will guarantee your Windows password reset successfully. Windows Password Genius is such a tool made for Windows password recovery, including all the Windows operational system and applying to different kinds of password.
Refer to:
http://isunshare.blogspot.com/2013/08/easy-way-to-reset-windows-password.html
May 27, 2012 | HEWLETT-PACKARD G56-129WM Laptop PC
How to reset cartridge chipe laserjet cp1525nw
You have to replace the cartridge. The chip is siliconed in.
Mar 01, 2012 | HEWLETT-PACKARD CP1525NW Laser Printer
How can i reset password of my laptop? (Amilo
Here I recommend some popular solutions on forgot Windows password to help you reset laptop password on Windows 7/Vista/XP.
Solution 1 Reset laptop password by another user account with administrator privilege.
Solution 2 Reset laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset laptop password with pro Windows Password Recovery Tool.
Jun 23, 2009 | Computers & Internet
Dell inspiron password removal hdd
Usually, the hdd password is set the same as bios password. So we can recover the BIOS password directly from the laptop security chip. But if the hdd password is set not the same as bios password, how do you remove hdd password for Dell inspiron?
Therefore, you have to use password cracker only. If you still remember hard disk password, or you remember bios password and bios password is the same as hard drive password, follows the below article to remove it.
http://isunshare.blogspot.com/2013/11/how-to-remove-hdd-password-on-acer-laptop.html
May 06, 2009 | Dell Inspiron 700M Notebook
HP Laser Jet Pro CP1525N Logo
55 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
