Question about Culligan 34" Whole House Water Filter Housing Wrench Use
How do I install an omni water filter.
What are the parts to install whole house water filter. 3/4 in inlet and outlet
How to replace oil; cooler on this year
  • Service and Repair
Oil Cooler Replacement
Removal Procedure
  1. Raise and support the vehicle. Refer to Vehicle Lifting.
  2. Drain the engine oil and remove the oil filter housing.
89116492
  1. Loosen the oil cooler outlet (1) and the inlet (2) lines from the engine block.
  2. Lower the vehicle.
  3. Remove the intake plenum.
  4. Remove the intake manifold.
89116493
  1. Disconnect the following electrical connectors from the water crossover:
    • The engine coolant temperature sender (2)
    • The engine coolant temperature sensor (4)
84936658
  1. Remove the water crossover bolts (1).
  2. Remove the water crossover upper and lower seals (2).
84942881
  1. Loosen the upper heat shield bolts on the left side of the exhaust manifold.
89116496
  1. Remove the oil cooler outlet line from the engine oil cooler.
  2. Remove the oil cooler inlet line from the engine oil cooler.
84942883
  1. Note the positioning of the 4 seals.
84972057
  1. Position the oil feed and return,lines out of the way and secure with mechanic wire.
  2. Remove the engine oil cooler, inlet and outlet nuts (1).
  3. Remove the engine oil cooler cover bolts (2).
84942883
  1. Remove the engine oil cooler cover.
  2. Remove the engine oil cooler.
  3. Clean all sealing surfaces.
Installation Procedure
84972056
  1. Install the engine oil cooler.
  2. Apply a 2 mm (0.08 inch) bead of RTV silicone sealant, GM P/N 12346240, in the groove around the engine oil cooler cover.
  3. Install the engine oil cooler cover.
Notice: Refer to Fastener Notice in Service Precautions.
84972057
  1. Install the engine oil cooler cover bolts (2). Tighten the engine oil cooler cover bolts to 30 Nm (22 ft. lbs.).
  2. Install the engine oil cooler inlet and outlet nuts (1). Tighten the engine oil cooler inlet and outlet nuts to 20 Nm (15 ft. lbs.).
  3. Reposition the oil feed and return lines.
84942883
  1. Install the oil cooler outlet and install the oil cooler inlet lines to the engine oil cooler. Use 4 new seals.
Tighten the oil feed and return lines to 30 Nm (22 ft. lbs.).
84936658
  1. Install the water crossover:
    • Position the crossover.
    • Install the upper and lower seals (2).
    • Install the water crossover bolts (1). Tighten
Tighten the water crossover bolts to 30 Nm (22 ft. lbs.).
  1. Connect the electrical connectors at the following locations:
  1. Install the intake manifold.
  2. Install the intake plenum.
  3. Raise the vehicle.
89116492
  1. Install the oil cooler outlet (1) line to the engine block. Tighten the oil cooler outlet (1) line to 30 Nm (22 ft. lbs.).
  2. Install the oil cooler inlet (2) line to the engine block. Tighten the oil cooler inlet (2) line to 30 Nm (22 ft. lbs.).
  3. Install the oil filter housing to the engine block. Tighten the oil filter housing to 45 Nm (33 ft. lbs.).
  4. Lower the vehicle.
Dec 22, 2014 | 2001 Cadillac Catera
How do you change a culligan water softener filter
The filter housing will have either a shut off valve before and after the housing or a valve on top of the housing that turns (Black).
Shutoffs before and after.
1. Turn both valves off
2. Push the "red button" on top of filter housing and hold to relieve the pressure off housing.
3. Unscrew housing to the left (lefty loosey, Righty tighty) You should have a housing wrench.
4. Remove filter, clean housing, lubricate the o-ring with silicone lubricant.
5. Replace filter, Screw housing back on (Hand tighten only)
6. Open inlet valve (slightly) while holding down the "red button" to relieve air in housing.
7. Open inlet and outlet valves and you are back in business.
PS if the housing is very difficult to remove.
1. Shut off inlet valve
2. Open the nearest cold water faucet and let it run until no water
3. Shut off outlet and repeat procedure as above
Good Luck, RJ
5.
Sep 29, 2011 | Culligan Sediment Water Filter
I need to replace a thermostat in a 2000 Chevy 2500 6.0 liter pickup
4.8L, 5.3L and 6.0L Engines To Remove:
CAUTION
The thermostat is not serviceable separately. The thermostat housing (water pump inlet) and thermostat must be replaced as an assembly.
  2. Remove the bolts from water pump inlet.
  3. Remove the water pump inlet from the water pump.
To Install:
  1. Install the water pump inlet to the water pump.
  2. Install the water pump inlet bolts.
    • Torque to: 11 ft-lbs. (15 Nm)
  3. Install the radiator outlet hose.
6.6L Engine To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Drain the engine coolant.
  3. Remove or disconnect the following:
    • Water outlet 6.6L Thermostat housing removal gm_trk_sil25_02-04_66_therm_hous_rem.gif
    • Bolt for the fuel line bracket
    • Thermostat housing cover bolts
    • Thermostats and seals
To Install:
  1. Install or connect the following:
    • Thermostats and seals to the thermostat housing NOTE: The rear thermostat (D) has 2 vent valves. Install with the vent valves towards the rear of engine.
    • Thermostat housing cover with a NEW gasket
    • Thermostat housing cover bolts and tighten the bolts
      1. Torque to: 15 ft. lbs. (21 Nm)
    • Fuel line bracket bolt and tighten the bolt
    • Water outlet
  2. Fill the engine with coolant.
  3. Test drive the vehicle to confirm the repairs.
8.1L Engine To Remove:
  2. Drain the cooling system.
    • Inlet hose from the water outlet Water outlet and thermostat removal chevy_sub25_02-04_60_thermost_rem.gif
    • Water outlet bolts (B)
    • Water outlet (A)
    • Thermostat (C)
To Install:
    • Thermostat
    • Water outlet
    • Water outlet bolts and tighten the bolts.
      1. Torque to: 22 ft-lbs (30 Nm)
    • Inlet hose to the water outlet
  2. Fill the cooling system.
Jan 12, 2011 | 2000 Chevrolet 2500
I bought my home in 6/09, there is a omnifilter wholehouse water filter u25 installed, in the basement. On the top of the product it says bypass. My question is What does this filter do exactly and what...
Inside the housing is a replaceable filter cartridge. Filters used for this type whole house filter housing come in micron ratings from 5 micron - 50 micron. The smaller micron the finer it filters (that is not always good because it can significantly reduce flow rate and pressure in home). 30-50 micron filters are the most common used. The filter should be changed every 3 months minimum and sanitized with a a cap full bleach when reinstalling filter. Omni filter housings are notorious for the bypass leaking when turned and the bypass freezing up to where it won't turn. There are no manuals for this.
You can find filters at most any hardware store or water treatment company.
RJ
Aug 23, 2010 | Plumbing
Want to know how to change a thermostat on my 2004
It Depends on which engine you have, this is how it goes for both. I use a little RTV with a new ring as well.
THERMOSTAT REPLACEMENT (4.2L ENGINE)
Removal Procedure
1. Remove the necessary coolant from the radiator.
2. Remove the generator.
3. Loosen the outlet hose clamp at the thermostat housing. Remove the outlet hose from the thermostat housing.
4. Remove the thermostat housing bolts.
5. Remove the thermostat housing from the engine block.
6. Clean all of the surfaces of the thermostat housing.
7. Clean the sealing surface of the engine block.
1. Install the thermostat housing to the engine block.
2. Install the thermostat housing bolts.
Tighten: Tighten the bolts to 10 N.m (89 lb in).
3. Lubricate the inner diameter of the radiator hose with engine coolant.
4. Install the outlet hose to the thermostat housing. Secure the hose with the clamp.
5. Install the generator.
6. Fill the cooling system with specified coolant and concentration. Follow the correct cooling systen bleed procedure for your engine.
7. Inspect all sealing surfaces for leaks after starting the engine.
THERMOSTAT REPLACEMENT (5.3L ENGINE)
1. Drain Radiator and remove the radiator outlet hose.
2. Remove the water pump inlet bolts.
3. Remove the water pump inlet and thermostat from the water pump.
IMPORTANT: The thermostat is not serviceable separately. The water pump inlet and thermostat must be replaced as an assembly.
1. Install the thermostat and thermostat housing to the water pump.
2. Install the thermostat housing bolts.15 N.m
4. Fill the cooling system with specified coolant and concentration. Follow the correct cooling systen bleed procedure for your engine.
5. Inspect all sealing surfaces for leaks after starting the engine.
Mar 17, 2010 | 2004 GMC Envoy
I have a 1999 Ford SHO that needs a new waterpump. I need to know how to replace it and where I can get a schematic of it. Do I need a special tool kit to do it? I'd also like to know where I can get the...
www.autozone.com
They can get all the parts. They also provide haynes repair manuals, any special tools (probably not required for this vehicle) and any special disassembly instructions.
I hope this helps.
Mar 11, 2010 | 2001 Ford Taurus
2002 grand prix motor 3.8 just want to know where
Exploded view of the thermostat arrangement—3.8L engines
Oct 31, 2009 | 2002 Pontiac Grand Prix
Where is the thermastat 2006 la cross
3.6L Engine
  1. Remove the heater hoses.
  2. Remove the throttle body.
  3. Remove the radiator water pipe outlet.
  4. Remove the thermostat and housing.
    NOTE The thermostat and housing are replaced as a complete unit.
  5. To install, reverse the removal procedure. Tighten the housing bolts to 15 ft. lbs. (20 Nm).
3.8L Engine
  1. Remove the fuel injector sight shield.
  2. Partially drain the cooling system.
  3. Remove the radiator inlet hose from the water outlet housing.
  4. Reposition the wiring harness from the water outlet housing stud.
  5. Remove the water outlet housing bolt and the stud.
  6. Remove the water outlet housing and the gasket.
  7. Remove the thermostat.
  8. Clean and Inspect the water outlet housing gasket mating surfaces.
To install:
  1. Install the thermostat.
  2. Install the gasket and the water outlet housing.
  3. Install the water outlet housing bolt and the stud to the water outlet housing and tighten to 20 ft. lbs. (27 Nm).
  4. Install the wiring harness to the water outlet housing stud.
  5. Install the radiator inlet hose to the water outlet housing.
  6. Fill the cooling system.
  7. Install the fuel injector sight shield.
Oct 13, 2009 | 2006 Buick LaCrosse
Culligan 34" Whole House Water Filter Housing Wrench Use Logo
63 people viewed this question
Top Culligan Welding Tools Experts
Bill Boyd
Are you a Culligan Welding Tool Expert? Answer questions, earn points and help others
