Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU
Yellow heating light is on - Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Tip
Fuse list ford contour
Engine bay fuse box
3 60 Yellow ABS
22 7.5 Brown ABS
32 7.5 Brown Radio
38 Unused
Engine bay fuse box
R3 Blue AC cut-out
R4 Brown AC clutch
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R16 Black Ignition
R17 Unused
R20 Unused
R21 Unused
R26 Unused
Glove box
Step/Courtesy light
Trunk/Cargo area
Instrument-general
on Apr 15, 2015 | Ford Contour Cars & Trucks
Tip
Yellow light of death PS3 (Playstation 3)
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
on Jul 26, 2010 | Video Game Consoles & Games
PS3 - Yellow/white light
It sounds like the yellow light of death (YLOD) This is usually an issue with the heat sync inside has lost a connection with the solder because of overheating. An easy fix with the proper tools. eBay sells a inexpensive kit to fix that very problem. The only tools you will need that probably won't be provided, are a Philips head screwdriver, and a heat gun. (NOT A HAIRDRYER) as they don't get hot enough. ******IMPORTANT*******MAKE SURE TO COMPLETELY CLEAN THE SURFACE AREA OF THE HEAT SYNC TO ENSURE A PROPER APPLICATION OF HEAT TRANSFER PASTE!!!!!!!********** Then again, if it's still under warranty, just send it back for a free repair. Hope this helps, good luck.
Apr 16, 2013 | Sony Playstation 3 (PS3) Console
Ps3 doesnt turn on yellow light appears then it
This is the YLOD yellow light of death you need to fix this by stopping the heat internally use a good guide or send it in to be fixed.
Jul 04, 2010 | Sony Playstation 3 (PS3) Console
Yellow Light
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
Yellow light
Sep 30, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on it goes green then yellow and then to flashing red
Yellow light of death. Actually there is no yellow light. It's an illusion when that half a sec that boath the green & Red lights are on. Only one way to fix that is a reflow of the GPU & CPU. Similar to heating the solder points on an xbox, just not as big a success rate and the only two things you have to heat up are the two squares in the middle of the motherboard. Take a heat gun on low setting to those two squares for 4 minutes and cool for 14 minutes then flip the board over and do the same on top, and cool for 14 minutes.
Aug 30, 2009 | Sony Playstation 3 (PS3) Console
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
How do i light my dega 100 mj spa heater. It says I have power (yellow) light - but does not say heater is on
if it has a yellowlight chances are it is an electronic ignition system.need more info
May 17, 2009 | Pool & Spa
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU Logo
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
