Question about Ovens
Linea oven manual l156.2ss
Need to take off so I can clean it properly.
HOW DO I PROGRAM MY LINEA L186.2SS TO COME ON, OR TO TURN OFF, AT A CERTAIN TIME?
that is probably normal since most recipes I ever saw start with preheated ovens not cold
Jan 31, 2015 | Ovens
How do I get an instruction manual for A linea oven model number Las3ss
Go online with make, model etc and or contact a seller of the manufacturer or go to the manufacturer website.
Sep 21, 2014 | Ovens
Smeg Wall Oven SCA504X Repair Manual
minimum repair is the clearance side wall of at least 110 mm. but never attempt to repair the appliances by your self. it has so many things which need skilled person but proper cleaning and lil bit maintenance for small damages is quite safe.
Dec 12, 2011 | Ovens
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
I need to get my oven unlocked. The cleaning cycle went haywire
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Oct 25, 2009 | Whirlpool RBD305PD Electric Double Oven
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
or
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 | Ovens
My electric oven will not lock the door to have it self clean
The most likely problem is that the motor that drives the locking mechanism is defective.
Mar 30, 2017 | Ovens
Ovens Logo
185 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
