Question about Microwave Ovens
What is replacement microwave to sharp model R1830
4 Suggested Answers
  • 8404 Answers
SOURCE: Sharp Microwave Model R-510B Light burned out -
Generic answer:
You probably have to remove the case. DO NOT TOUCH THE SILVER CAN - LETHAL. There are probably 8 phillips or torx head screws to remove the cover.
Alternatively, their may be access inside, where I would look first.
Let me know if this works.
a
Posted on Sep 23, 2009
jsrock516
  • 5911 Answers
SOURCE: Need to Replace door on a sharp R1830 B how would
On MOST microwave ovens all you have to do is open the door all the way and lift straight up at the hinges. The door simply lifts all the hinge pins. You may have to remove the upper grill cover (if equipped) to accommodate.
NOTE: On some models there is a small hinge pin on the upper hinge that you need to remove first.
If you have questions, please let me know. I hope this helps you.
Posted on Oct 08, 2009
Testimonial: "Thanks much so simple I should have figured it out. thanks again"
  • 1891 Answers
SOURCE: Trying to remove my Sharp R1830 microwave. We
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Posted on Jan 10, 2010
Testimonial: "Thanks so much...appreciate your help. The old microwave is now off and a new one in its place! Thanks again!"
User manual for a model R-209 AK counter top carousel microwave
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Top Automotive Device Types ..... Sharp M I C R O WAV E O V E N OPERATION MANUAL. Pages: 0 ... Sharp Microwave Oven 209H ... SharpOperation Manual Microwave Oven R-308H, R-305H .... Sharp Microwave OvenMODEL R-2197 ... Sharp over the counter microwave oven operation manual ...
SHARP MICROWAVE OVEN Parts ' Model r209ak ' Sears ...
www.searspartsdirect.com/model-number/r209ak/0958/0123245.html
Shop for SHARP MICROWAVE OVEN repair parts for model r209ak at Sears ... Find part in diagram SHARP Countertop Microwave Model # R-209AK.
Jan 07, 2016 | Sharp Microwave Ovens
How do I replace the inside light on my R-520 ks Sharp Microwave
I don't know the exact model but most MWs have a plastic panel that pops off easily. Some, however you must take the cover off the MW oven. Just a tad more difficult.
Dec 25, 2014 | Sharp Microwave Ovens
Get a replacement bulb for sharp carousel microwave table top oven .
A quick look at the manual doesn't specify the part #. It just says replace with the same type and not more than 30 watts. http://www.sharpusa.com/downloads/archives/product_manuals/mic_man_r1500_1501.pdf
Here is a link to an online parts place that you can enter with your model #:
Replacement Sharp parts Select from 266 models Microwaves
Dec 08, 2014 | Sharp Microwave Ovens
I REQUIRE A WAVEGUIDE COVER REPLACEMENT SHARP
Here's a link to the parts listing at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R120DK/0958/0123245?searchedModel=r-120d&blt=
The list also includes helpful schematic diagrams that you can print for future troubleshooting.
if you need further assistance, please post back and let me know. I hope this helps you.
Nov 03, 2010 | Sharp R-120D Microwave Oven
Trying to remove my Sharp R1830 microwave. We removed the top screws (into the shelf above) and the thumb screws at the bottom of the microwave that clip into the back wall bracket; but the clips seem to...
Jan 09, 2010 | Sharp R-1480 Microwave Oven
Need to Replace door on a sharp R1830 B how would I go about doing this?
Oct 08, 2009 | Sharp Microwave Ovens
Replacing inverter board for my sharp R-2130JS microwave
I do not know how to specifically replace the "inverter board" in this model. On most microwaves I've repaired, though, the hardest part is getting them dismounted from the wall if they are rangehood models. I suspect that the inverter board is held onto the chassis with two phillips screws, and all the connections thereto are modular and therefore easily disconnectable and swapped out. The great majority of times, manuafactureres do NOT put multiple connectors of the same pin count and oriention on a circuit board. Give it a go.
Feb 27, 2009 | Sharp R-2130JS Stainless Steel 1200 Watts...
Microwave oven inoperative
When you enter the time then hit START, does the turntable motor come on? If not, then I would suspect the secondary interlock switch, its mount, or its wiring. If so, then it's hard to say, unless there was some miswiring somewhere. The original problem sounded like just a classic bad door switch. At this point I suspect the wires on one of them may not have been reconnected exactly where they were. It does matter. I would suspect the secondary interlock switch, which MAY have white/white and grey/grey wires attached. Also, one of the switch mounts may have a broken tab that makes the switch move so it's not getting activated. At our site, we have the service manual for the R1830, which is similar to the R1480-series. We have that plus *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 27, 2007 | Sharp R-1481B Microwave Oven
Microwave Ovens Logo
124 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
