Question about Fisher Paykel EcoSmart GWL15
I have a 7.5kg excellence smart drive and stops when it gets to the rinse cycle. Any suggestions?
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Machine stops and beeps every second. Tried various points in cycle. pump appears to work then stops. Its a smart drive excellence 7.5 kg
it sounds like your out of balance switch is open circult.out of balance switch is located under control module.test for continuity on switch.make sure power is turned off first.if u have problems reply 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
Installing a new waste outlet hose
You will have to remove the outer shell to access the pump.
Remove the clamp from the outlet side.
Install is the reverse.
Thanks
May 15, 2009 | Plumb Pak Continuous Waste Center Outlet,...
Fisher Paykel EcoSmart GWL15 Logo
19 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
