Question about Lite On Spark Plug Lite Green LED
I have no spark from dis
Repalced coil cap and rotor and had module tested still nothing
Ignition mystery! 1994 GMC Suburban 2500 5.7 mtr. No spark to spark plugs. Have spark from coil to distributor. Have changed coil wire, cap, rotor, ignition module, and coil. have 12.5 volts going to...
I guess you could have the ignition analyzed on an oscilloscope. Maybe a tech could see something then.
I always heard the only gap was the spark plug gap-the rotor has no gap-are you sure you got the correct rotor? And does it touch the top distributor cap coil wire tower?
Let us know. It is a mystery worthy of a solution.
Sep 21, 2013 | Chevrolet Suburban 2500 Cars & Trucks
94 chevy 1500 4.3 no spark no fuel
Sounds like you replaced alot of parts for nothing.
The pickup coil in the distributor "fires" the module which grounds the coil and the injectors.
Those components would need to be tested. The coil fires the plugs when the ground is removed by the module or the key switch.
Jan 08, 2013 | GMC C1500 Cars & Trucks
No spark from spark plug wires I think it may be the distributor cap or interior parts under cap like rotor and condensor but dont want to change parts thats are fine i replaced the plugs but still no...
There wrere two types of HEI (High Energy Ignition) distributors used by GM in 1985, one was the original design with the ignition coil mounted in the top of the distributor cap, and the second had the coil mounted seperate from the distributor and used a coil wire.
There is the possibility that the ignition coil is faulty and first check to see if full battery voltage is even getting to the "Pos" (+) positive side of the ignition coil when the key is in the "Run" position, and also if the coil is seperate from the distributor that full battery voltage is getting through the "Pos" (+) or positive side of the ignition coil and over to the distributor ignition module, dis-connect the wire connector from the ignition module and if battery voltage is not present at the connector to the ignition module with the key in the "Run" position but it is present at the "Pos" side of the ignition coil, then the ignition coil is faulty. If battery voltage is present then check the ohms between the high tension terminal (where the coil wire goes on the ignition coil) and the "Pos" terminal on the ignition coil by first dis-connecting the wires from the ignition coil and then test with the "Neg" lead from the ohm meter in the high tension terminal on the ignition coil, and the "Pos" lead from the ohm meter to the the "Pos" terminal on the ignition coil, and the ohm reading should be between 6,000 and 30,000 ohms and if not replace the ignition coil. A faulty ignition coil can also damage the ignition module.
The ignition module and the pick-up coil/stator located inside of the distributor is what generates the signal that the ECM (Engine Control Module) uses to time and fire the fuel injectors, as well as the signal to run the fuel pump and the dwell signal timing to fire the ignition coil, and a faulty ignition module can cause any one of these systems to malfunction.
That could be a malfunction with the ignition module inside of the distributor, and you can remove the ignition module and have it tested for free at most auto part stores. If the ignition module does test out alright then the problem could still be in the pick-up coil/stator, (it can be tested using an ohm meter by dis-connecting the wire connector from the pick-up coil/stator and the ohm reading between the two wires from the pick-up coil/stator should be between 500 and 1500 ohm's, and both of the wires from the pick-up coil/stator should show an open loop or an infinite reading between each wire and ground) and if the pick-up coil/stator is found to be faulty then replace the entire distributor, or the distributor will have to be dis-assembled to install a new pick-up coil/stator.
If you do purchase a new ignition module be sure that it does come with a silicone grease or a die-electric compound because it is a heat sink and the ignition module will burn up without it.
To install the new ignition module first clean out the mounting surface inside of the distributor. Then completely coat the metal contact surface under the ignition module with a thick coat the silicone grease or die-electric compound and do not leave any of the metal contact surface of the ignition module un-coated with the silicone grease or die-electric compound, and be very careful not to over-tighten the ignition module or it will be damaged.
Let me know if you require any further assistance.
GM HEI Ignition Coil (Mounted In Distributor Cap Type)
Jul 30, 2010 | 1985 Chevrolet Chevy
Cant get spark to start engine bought coil dis cap rotar arm and ignition module still nothing any tips plz?
Check the thin wires going TO the coil with a test light, if you have no current then your coils won't fire.
Apr 02, 2010 | 1995 Chevrolet Cavalier
1989 GMC engine turns great , no spark at coil or plugs, had coil tested and repalced- new rotor and cap. not sure where to go next
Check your fuses (ECM) and also recheck your wire leads to the coil. Your ICM (ignition control Module) may also be bad, it's located in your distributor under the rotor. You can have that tested also to make sure it's working 100%, there common to go bad from corrosion caused by condensation under the distributor cap.
Thank you for using Fixya and good luck.
Mar 20, 2010 | 1989 GMC K1500
1987 Ford Ranger. Won't fire.
Ignition module comes to mind. If you've tested for spark (holding spark plug wire near the block when cranking) and the cap and rotor are good, it seems the module is the only other area left to try. Best of luck Patrick. Please post back with any other questions.
Greg
Jun 12, 2009 | 1987 Ford Ranger
Replaced entire ignition still no spark 88 305 ci
There are 3 possibilities. 1 the coil. 2 the ignition module. 3 the pick up coil. In my experience the ignition module is the most common cause. It is in the distributor held in with 2 screws. The coil and module can be tested at any parts house. Good Luck
May 26, 2009 | 1988 Chevrolet Suburban
Computers & Internet Logo
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
