Question about Mission MS8 Subwoofer
How to fixe a fuse on a mission subwoofer - Mission MS8 Subwoofer
3 Suggested Answers
  • 10 Answers
SOURCE: blown fuse in mission 700as subwoofer
if you have access to a multimeter, you should test you impedance (ohms) Ω, check to make sure the speakers reads higher than the amplifier needs; this will result in less strain on your amp and diminishement of sound...For example: if you connect two 4Ω
speakers in series it results an 8Ω circuit (least strain). and if you'd take the same two speakers and connect them in parralelle it would result in a 2Ω circuit (most strain).
Posted on Jul 24, 2009
Grubhead
  • 5056 Answers
SOURCE: My Mission MS10 subwoofer keeps blowing it's fuse.
Anything in the power supply will cause it, look for damage or burnt parts, anything on heatsink. A transistor with a short circuit. For instance if you put an ohm meter probe to the leg of one and the other probe on to another leg, it will be read on the meter as if you had put your probes on the same leg.
Posted on Jan 12, 2010
I have a mission m5as sub wondering what fuse does it take as it is internal
Why not open it up and check? My guess would be about 5 to 8 amps 25mm .
Nov 16, 2015 | Mission Audio Players & Recorders
Hi, I have a Mission M5AS Sub and for some reason it has just stopped working. The power light is on, but it doesn't become active when music is played. Simple to resolve or a job for Mission? Any...
Hi, yes there is a rather simple method for testing the actual subwoofer unit, simply plug in a known good rca cord into the input-make sure if there is a switch for level input that it is on the back make sure it is switched to line and not level, next plug in rca cord, turn on unit-stick tip of finger on tip of rca cable. This should gernerate a"HUMM" in the subwoofer if everything is working correctly. Thanks for choosing FixYa, I hope this was of some help,good luck Prodzilla.
Apr 13, 2011 | Mission M5AS Subwoofer
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
My Mission MS10 subwoofer keeps blowing it's fuse. Possible problems?
Jan 11, 2010 | Mission MS8 Subwoofer
Blown fuse in mission 700as subwoofer
Jul 24, 2009 | Mission 700 Main / Stereo Speaker
Subwoofer blowing internal fuse as soon as you power up
check your bridge rectifier if no short,audio stage is blown
Jul 15, 2009 | Mission M-CUBE System
Mission ms8/ms10
Silly question but did you check the fuse and if so is the sub pluged into the sub out put on your amp and not the sub six channel input as this will result in no sound.
hope this helps.
CABLE GUY.
Jun 29, 2008 | Mission MS8 Subwoofer
Subwoofer eating fuses.
Check the circiut board for any blown capacitors. Sometimes it's that simple as replacing a capacitor. But then again, what is causing the capacitor to blow??/ Hope this helps.
Nov 02, 2007 | Audio Players & Recorders
Mission MS8 Subwoofer Logo
80 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Steve K
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
