Question about Pride Mobility Products Jazzy Select
What is lock out mode and how to get out of it
Jazzy gt select gt batteries werew dead and i replaced them the led lights flashed i could not count before it stoped now its dead and wont turn on
  • Pride Mobili... Master
  • 10,045 Answers
Turn on the key, hold until it beeps. Push the joystick full forward until it beeps, pull the joystick full back until it beeps. It is now unlocked
Posted on Oct 01, 2016
  • 175 Answers
SOURCE: have jazzy select series need to know flashing Code #9
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
Posted on Jul 09, 2009
  • 29 Answers
SOURCE: jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
Posted on Sep 07, 2009
  • 945 Answers
SOURCE: jazzy select 14 won't charged - have replaced
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life. Also the new batteries need to be charged before they are put on your jazzy. Then its a matter of if not in use put on charge. I think you need to have a word with your dealer.
Posted on Oct 19, 2009
  • 692 Answers
SOURCE: my jazzy select 14 keeps lighting up like its
Can you tell if the lights are flashing a number of times then pausing slightly then flashing the same number again and so on? If not then check to make sure your not in "freewheel". The levers are behind each wheel If you are getting a flash code determine the number of flashes the codes should be in your user manual or goto and you can download a owners manual for that chair. Hope this helps
Posted on Aug 22, 2010
  • 132 Answers
SOURCE: my jazzy select 14 on
well a wrench means the obvious that something needs adjusting , if it came with an instruction manual search for the code 9 blinks will mean.
Posted on Oct 16, 2010
My chair is blinking 4 times and I do not have a manual
If it is a Pride Jazzy or similar, the Diagnostic Flash Codes are in this PDF file.
PDF]INFINFB2048_Jazzy_Select_14_Troubleshooting ... - Pride Mobility
  1. Cached
  2. Similar
basic troubleshooting instructions for the Jazzy Select 14/14XL power chairs. ... on my Jazzy Select 14/14XL seem to be "dead" (controller does not light up when .... What if the left red battery condition meter LED on the VR2 or VSI is flashing? chair is blinking 4 times Google Search
Nov 15, 2016 | Health & Beauty
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
Series of lights flash on control. Why no response?
Most likely cause is the joystick is in LOCK mode.
Turn Off and On
Hold joystick forward till you hear a beeb
Hold joystick back until you hear a beep
Jun 30, 2015 | Pride Jazzy Select Gt With 2 Batteries In...
The control panel flashes its lights and chair wont move
When my Pronto did this, it was diagnosed as a failure of the controller. Replacement was about $1200. Good Luck.
Dec 09, 2014 | Health & Beauty
Hi, I recently bought my mother a used jazzy select power chair. I had to buy a charger when i powered up the leds flashed from left to right the first led is red than 2 orange and 2 green. Is this no
Check that the unit has the drive engaged levers near the motors in drive mode, could be on free -wheel mode. OR joystick could be locked out by mistake. If so, turn on unit hold joy stick forward until it beeps then hold in reverse until it beeps. This will unlock it OR it will lock it back again. Some units require you to turn on unit and hit the horn button twice, this will unlock or lock up unit.
Mar 12, 2014 | Pride Mobility Products Jazzy Select 6...
My batteries in my jazzy select gt power chair are dead.would it be possible to replace them with a car battery.
I would not recommend you to do this. The batteries that are used for this application are a deep cycle battery. A regular battery may get hot and you will just have problems. Get the correct batteries for the unit. They take U1 32Ah 12V batteries.
Jul 24, 2011 | Pride Mobility Products Jazzy Select
Y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
Jun 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy jet 3
Sep 06, 2009 | Pride Mobility Products Jazzy 1103 Ultra...
The battery is charged but the lights just flash and chair doesn't move
Make sure the charger is unplugged from the chair and that the chair is in gear. There's two levers that place the chair in freewheel, or neutral so you can roll it around. Place these in neutral, then back in gear firmly. If still flashing, turn chair off, wait three seconds and turn back on, then push on the horn button three times. This will take it out of sleep mode. Still not going, you will need to check all clip-on connections to make sure they are tight.
I am assuming that all of the lights are flashing constantly. If it flashes a "fault code", you will get a series of flashes from 1 to 10, then a pause, then a set of flashes. Count the number of flashes and it will tell you what the fault is for that number of flashes in the owners manual. If it is just two red lights flashing constantly, you have a set of dead batteries.
Good luck.
Jul 11, 2009 | Pride Jazzy Select 6 Indoor Power...
Pride Mobility Products Jazzy Select Logo
195 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
