Question about Krups FBC212 1600 Watts Toaster Oven with Convection Cooking
Why do Heat Elements not work, timer control panel does?
My toaster oven quit working--the led display lights up just fine but no heat. I unplugged/replugged and it worked! for awhile. Then, the same thing and the plug had no effect.
take it in to an appliance repair shop as it may be the elements or thermostat control that is faulty
get a quote as the repair may be more expensive than a replacement unit
Jun 16, 2017 | Toaster Ovens
Oven works but is not heating up what can I do or check for to restore heat
Check for correct power at the heating elements, if its there, the elements are burned or shorted.
Mar 07, 2015 | Lincoln 1301/1346 50" Electric Impinger...
Bravetti toaster oven
Not enough voltage getting to the heating elements. Look at the thermostat or the control board for the problem
Jul 28, 2017 | Toaster Ovens
I have a Brevelle 800 toaster oven that starts, but does not heat up. What part needs replacing?
There is a thermal fuse that breaks power to the heating elements if it gets too hot (somewhere around 173 C. I replaced mine with an identically rated fuse and it was good for a week until I tried to cook twice in succession. I then replaced the fuse with one that trips at around 190C and it's been good for 4 months now. The fuse costs about $6 on ebay (shipping included) and takes about an hour to replace.
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
West Bend MC38ACL convection oven
Yes normally a fuse which they replace for it to heat again generally goes when over heated especially if not in a air flow area will cost about $100 - $120 to fix local electrian
Apr 06, 2014 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Fan works timer works but no heat
There is no fuse. Take back cover off and all bottom perimeter screws. Outside cover pulls off towards rear once you get all the ** little screws out. Chances are you will find burned connections on the heating elements poking out the sides of the heating chamber. Try cleaning these and squeeze them tighter before reconnecting. Good luck!
Oct 22, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
Krups FBC212 1600 Watts Toaster Oven with Convection Cooking Logo
Top Krups Toaster Ovens Experts
warcraft demonhunter
Level 1 Expert
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
