Question about Electrical Supplies
Where to locate the serial # on a wen power 2200 watt generator
2 Suggested Answers
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Posted on Mar 16, 2009
Gas is pouring out of new generator. It seems to leak at point where gas goes into filter.Tightened hose. Still pours. Any ideas
Sometimes gas leaks appears to be leaking in one place when it is actually leaking from another place. I assume that the fuel feed is by gravity from the tank to the filter and to the carburettor. Did you check the hose that is attached to the bottom of the tank? it may be ruptured; check both clamps and make sure that there are no shavings to the hose.
good luck
Apr 23, 2016 | Lifan Energy Storm 2200 Portable RV...
When I plug in a tool, it runs fine, when I plug it into my house with the breakers all off, it blows the breakers on the generator? My Honda 2200 watt works fine this way?
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
Oct 27, 2015 | Honda Electrical Supplies
Why does my Ryobi 2200 watt generator surge at low RPM's
Check for a weak or missing spring on the throttle linkeage.
Nov 17, 2014 | Electrical Supplies
That sounds like dirty/clogged idle circuit passages in the carbureator. A little spary carb cleaner might work, but you might have to rebuild it.
Engine governor sensitivity may be set too high, it keeps correcting too much, it's typical for all generators, 1 KW - 1 mega watts units.
I have a Wen Power Pro 9000, 16 HP Generator. Couldn't run my coffee maker this morning. Used a multimeter and was only getting 35 volts. Is it brushes or something more complicated. Rob
Rob
When was the last time this generator was run,allot of times they lose their magnetism from sitting so long? Also you may want to check your voltage regulator to make sure it is putting out the correct voltage..
Dec 27, 2010 | Watts Onan Portable Generator - 4000 ,...
Just up graded from a homelite 4400 to a craftsman 5600 generator 5600 does not have enough output as did the 4400 why
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Oct 03, 2010 | Craftsman Electrical Supplies
Where can i find fuel valve for a 3500watt generator by wen besides xmc products
should be on the tank where the fuel line comes out. May be another near the choke adjustment
Dec 04, 2009 | Watts Onan Portable Generator - 4000 ,...
I am need of a starter for a Honda RV generator EV 4010. Where is the starter located on the EV 4010? What do I need to remove on the unit to get at the starter?
ELECTRIC START WILL BE MOUNTED BETWEEN THE POWER UNIT AND THE GAS MOTOR IF YOU TAKE THE OUTER COVERS OFF YOU SHOULD BE ABLE TO SEE IT IT WILL LOOK LIKE A MINI CAR STARTER IF YOU NEED MORE HELP I MAY BE ABLE TO GET SCHEMATICS FOR YOU BUT I WOULD NEED MOTOR INFO MODEL BRAND SERIAL #S AND FROM THE POWER UNIT ALSO
Jun 18, 2009 | Watts Onan Portable Generator - 4000 ,...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
